pqrannes
Tubes warm your heart too
I've just bought a very nice looking Fisher X-100 (no dash A/B/2 or 3) - it is the one with the rectifier GZ34 tube.
The amp is in overall very fine condition and since it came with a quad of JJ El84s (and not 7189s) I ordered and got a quad of Sovtek el84Ms.
It is my plan you use the amp with my Danish three way Klipsch Bella'ish horns. And I am trying it out as I write this.
It does not sound bad, but it is a bit more clear/distinct at the top than I am use to with my other tube amps: the Braun CVS-13 (pp el84) amp, my Philips AG9015 (PP el86) amp and my little American Shell (SE El84M/7189) Northport.
The sound is not as 'fat' and tube-like as I know it from other tube amps.
Actually it wears my ears out.
After some listening I get very tired in my head and I almost have a ring in my ears. In a way it is very similar situation as when I first started to use my Braun on the three way horns: it rang in my ears until I found out a "presens" button that boosted the 1kHz to 15kHz by 6db was turned on! When I turned it off my problems were gone.
Well, back to the Fisher.
I gave the Fisher a try with another pair of speakers (Dynaco/Scandyna A-25 Xl) at a local vintage gathering this Saturday. We were listening to a vinyl record and I had to turn it off. It didn't sound right at all. It was much more bright than I have ever heard the A-25s even with SS gear (they are never bright, are they?).
I have tested all the tubes except the GZ34 on a very good (AVO 160) and newly calibrated tube tester. I've even put in vintage ECC83s that test better than the ones the Fisher came with.
The Fisher looks kind of unrepaired under the bottom with the plate off, but - note this - I know that the volume pot has been changed (the on/ff part didn't I was told from the seller).
The new pot seems to be a 1M ohm (it says so on it) but I am not sure that this is was the schematics suggest.
My question is thus this: can the wrong volume pot change the sound the way I describe it above?
I know the best to do is to recap the whole amp but it is not within my reach for the time being. I might get there one day but until then I just like to be able to listen to the Fisher without hurting my ears.
Peter Q (Denmark)
Peter Q (Denmark)
