:yes: I have the same passive pre, courtesy of fellow AKer doucanoe.
That would be a Penny & Giles potentiometer...silky smooth feeling, for sure.
A bit of the Mod Squad's history:
"The Line Drive series of passive preamps was produced originally by The Mod Squad, which then became the McCormack Audio Corporation. They were built in the California facility between 1984 and 1992. The design evolved over that period, incorporating a variety of different wire, solder, grounding arrangements, volume controls, RCA jacks, and switches. This evolution culminated in the development of the TLC-1 preamplifier introduced in 1992, and in production until about 2001.
The Line Drives were purely passive - there was no power supply and no active buffer. This feature was not added until the design change to the TLC-1. (For the sake of historical accuracy, I should add that a very small number of active preamps were built in the mid-80's using the Line Drive chassis. These were active/passive switchable, with an external power supply. Only a few of these were made so you will probably never see them.)
The Standard and Deluxe models are functionally identical. The difference is in several key parts that were chosen for cost-effective performance in the Standard model and cost-no-object performance in the Deluxe version. The Standard model has a Noble volume control; the Deluxe has a Penny & Giles or TKD (depending on vintage) conductive plastic control. Tiffany RCA jacks were used on both Standard and Deluxe units, but the Deluxe has WBT or Cardas jacks fitted in the CD, AUX 2, and MAIN OUT (1) positions. High-quality copper hook-up wire is used in the Standard model, while higher-performance wire was used throughout the Deluxe unit (again, the specific wire depends on when it was built).
Best regards,
Steve McCormack"
I also have a fine sounding little QED passive, which is not much larger than a pack of smokes.
