Chassis
- The layout keeps all AC wiring in a confined space and only filament leads go anywhere near the amp stage. The central power supply section is further isolated by 2 steel stiffening channels that run front-to-back in the chassis.
- Metal work is all 16ga. (.062) stainless steel and the wood is South American mahogany with Watco natural Danish oil and Satin finish wax – all wet sanded in up through #800 grit paper.
- A Grayhill rotary on/off switch is mounted up front through a stainless plate mitered into the back of the front panel and capped with an AudioNote gold plated brass knob.
- Corcom EMI filter IEC power cord socket in back.
- Tube sockets are Azuma gold & ceramic – I thought about Yamamoto for about a second till I saw the price.
- All tubes are mounted in stainless steel sub assemblies and I have a few ideas I want to try for shock mounting these – I hear the 417A can be pretty microphonic.
- The hum and level pots are topped with more AudioNote gold plated knobs.
- All hardware is anodized socket head machine screws accept plate to wood mounting where I used stainless screws.
- Not sure about feet yet, I might build something out of Ebony or just buy some off BrianB, maybe Vibrapods…
Power Supply
- Power transformer is a potted James Audio piece.
- 5U4 rectifier; so far have a NOS 5U4GB CBS black-plate and a National Union 5U4G to try.
- First stage filter will be 4.4uF foil & paper in oil, NOS Russian military caps.
- James Audio 5H/250ma potted choke.
- Second stage filter is 100uF Elna Cerafine, channels separate from here. I considered all PIO but was advised by someone who has built this circuit that I would get a better balanced sound combining a PIO first stage with a Cerafine or Blackgate second stage. Reading Reichert’s (AudioNote) design philosophy in Sound Practices also confirms the Blackgate/Cerafine choice and the single element availability and price lead me to choose Cerafines.
- Last filter stage to driver tube is again Cerafine.
- I’m using precision 10 turn Bourns pots for humpots on the 45 (Caddock resistor and a Blackgate cap). A humpot may not be necessary but I’ve read they’re needed with some tubes (like the TJ’s) and I want the flexibility.
- I’m adding a chassis top switch on the HV centertap lead to allow delaying the turn on of the HV till after heaters have been warmed – should be a little easier on these stupid expensive tubes.
- I’ll do a balanced center ground configuration on the driver heaters as I found this reduced hum a touch in my last amp.
Amp Section
- Vampire gold plated copper input jacks.
- Cardas shielded copper signal wire.
- Alps blue velvet level pot in a “shunt” configuration using Riken resistors. I was originally going to use a single grid stopper resistor in the signal path but I want to try bi-amping and I believe this is the best place to attenuate level on my Altec horns. It’s real easy to bypass the pot if I want but adding it in later would be a major bitch. A stepped attenuator would be better but way more bucks and I like the fine adjustment of a pot with the horns.
- I chose the 9 pin 417A as a driver based on recommendation and since I’ve heard it in this circuit and liked it. I have a few tubes to try here – Raytheon 5842, Northern Electric 417A and Western Electric 417A. Since I’m using a sub-assembly type socket mounting technique, I can switch to octals down the road if I feel adventurous; I made a set of octal plates just in case.
- I’m using Mills, Caddock and Tantalum resistors, Blackgate caps.
- For the coupling cap I’m going to try the Jupiter beeswax-paper-foil. I was going to use my current favorite AudioNote copper foil-in-oil caps but was impressed with the sound of this amp circuit using the Jupiter so I’ll start there.
- For 45’s, I have a matched pair of Raytheon STs and RCA UX-245 globes, down the road I’ll try some other oldies (a buddy has a bunch) and maybe the EML or TJ’s.
- Output trannies are again potted James Audio with taps available for variuos impedances - I’ll hard wire for 8ohm speakers but like the option of 16ohm and other power tube loading if I want to try them.
- Binding posts are un-plated Cardas copper – a little expensive but I like the idea of copper instead of brass.
- Wiring will be NOS Western Electric cloth/silk covered copper.
I’ve put together 2 of these chassis as my tube mentor buddy wants to build another copy of this amp for himself. This is a great help for me as I can see how things like grounding and wire routing are supposed to be done and I’ll again do initial power up on his workbench using a variac. Of course, this is AFTER he gives ‘my’ attempt at wiring a thorough inspection – it’s pretty humbling to have your stupid mistakes pointed out by an expert but I can think of a lot worse ways for a rookie to find them…
