Maxxarcade
This is going to be the thread I use for anything related to my amp project.
What I am building, is a Harman Kardon HK-250 based amp, with a larger power supply, pre-amp, multiple inputs, and some other tweaks.
Main parts list:
Hammond 17x10x3 steel chassis
Antek AN-3T325 power transformer
1N5408 full wave diode rectifier
Hammond 2.5H 300ma choke
50uf and 500uf cap banks
Edcor CXPP60-MS-6.6K OPTs
JJ 6L6GC matched quad
GE 6SN7GTB driver/inverter tubes
Sylvania 6SL7GT preamp tubes
NOS Amphenol brown octal sockets
NOS Alco solid aluminum knobs, black or plain depending on chassis color
The preamp is based on a circuit from an RCA manual and also handles the tone controls.
There will be 4 line inputs, a tape loop with LED indicator, and an auxiliary line output for connection to PC or other device. I may also add a headphone circuit with a DPDT switch and dummy load to keep the impedance low enough for the amp.
All parts are on order or on hand, and work has begun on the chassis. Center pilot holes for the OPT's, power transformer, 6L6GC's, and 6SN7's are marked and drilled. Next I will decide the placement for the 6SL7's and other hardware.
I want to thank everyone here who has helped me get this far. This is my first DIY tube amp, and I've learned so much by doing this!
Main parts list:
