sleepyweasel
Well-Known Member
I just got a a-960, but its not working. I read on another site(thevintageknob) that if the LED for the power button isn't lighting up then nothing will work? It will light up the mm or mc red led, but nothing else.
I only found one fuse (250v 12amp IIRC...pretty sure its good, because i get no red mm/mc light with it pulled) are there others, or is this led most likely the problem.....if so what do i do to fix(or bypass to check?) the led(sorry noob).
thanks for any help, -K
