Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-19-2009, 02:18 PM
retrodude's Avatar
retrodude retrodude is online now
AK Member
Yamaha CR-820 lights out
Hey all,
just picked up a cr-820. after cleaning some contacts, all is well, sounds sweet. the only thing is the lights are out-all of them. I see the red & white wires that go to the 3 bulbs near the meters- all filimets look toasted, so I assume the voltage is there. question: anyone have exp with changing these bulbs & where to find them? also, do the bulbs come wired? it looked like they are hard wired. the needle light looks like a bear to change, any thoughts?
thanks
  #2
Old 04-19-2009, 02:42 PM
sleepyweasel's Avatar
sleepyweasel sleepyweasel is offline
AK Member
maybe this will helphttp://www.audiokarma.org/forums/sho...d.php?t=223981
  #3
Old 04-19-2009, 02:47 PM
KingBubba's Avatar
KingBubba KingBubba is offline
"Too Much Stuff"
The A-690 issue does not apply here. The 820 and some of the others in the series have bulbs that are wired in series. I forget which but the meter bulbs come to mind. IIRC they are a bit of a pain and that is why I did not bother with my CR-820.
__________________
Sansui G6000,7070
Pioneer SX1250,SX1280
Kenwood KR-8010
Onkyo TX8500II
Pioneer CTF950,Akai GX-S80
DCM TF-600,TF-400 CX-17+ KL Quartets
  #4
Old 04-19-2009, 02:57 PM
merrylander's Avatar
merrylander merrylander is offline
AK Member
The 820 uses 12V 60mA bulbs (four) as in addition to the three around the meters there is one in the dial pointer. Use a good Philips #0 screwdriver bit to remove those two little screws atop the pointer because if you strip them they are not an easily obtainable size. Dave(dgwojo) can get you the bulbs.
__________________
"I shall pass through this world but once. If, therefore, there be any kindness I can show, or any good thing I can do, let me do it now; let me not defer it or neglect it, for I shall not pass this way again."
  #5
Old 10-02-2012, 07:07 PM
fengsuhi fengsuhi is offline
AK Member
After reading a lot of opinions here I bought a recapped Yamaha CR-820. I have replaced the lamps with 12v 60mA bulbs get from a local store. Everything went fine but one lamp is much brighter than the others. Did I something wrong? I soldered the wire directly to the board because the bulbs came with long wire, better solution than connect with the old wire.
Picture about the lights:http://i.minus.com/i3JjfToONddy5.jpg
Audiokarma
  #6
Old 10-02-2012, 07:10 PM
petehall347's Avatar
petehall347 petehall347 is online now
the brandy coffee man
check the rating of the bright bulb ..
  #7
Old 10-03-2012, 04:16 AM
AK Member
Quote:
I am new to electronics. There are no info on the bulbs and I don't have any device to measure them. I bought a spare bulb so I've replaced the bright one to this but nothing's changed. (Or accidentally I have two higher rated lamps.)
  #8
Old 10-03-2012, 05:06 AM
check your wiring ..here is part of the schematic ,,
  #9
Old 10-03-2012, 06:45 AM
AK Member
Maybe I messed up the wiring but I have the schematic and checked many times the connections. Is it possible that the bulbs are lighting but the wiring is incorrect? As I know they are in series connection.
  #10
Old 10-03-2012, 07:34 AM
dgwojo's Avatar
dgwojo dgwojo is offline
Away Alot @ UofM Hospital
I'd make sure all are identical and replaced at once to assure proper series circuit operation, most lamp sellers don't do that.
__________________
Altec 604-8K speakers bi-amped w/Elite80+ Tube Amps, BBE DS26, Vincent SA-31 & Cary SLP-50B preamp. Altec A7's. Jolida, Antique Sound Labs, and Acoustic Fidelity tube amps.
Audiokarma
  #11
Old 10-04-2012, 10:26 AM
AK Member
Quote:
Problem solved! Silly mistake: I swapped the L3 and L4 connections. On the schematics the connections comes like 1, 2, 4, 3 and I missed it. Anyway, I'm a newbie here, it was amazing how helpful and quick you are. Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
