Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-23-2009, 06:15 PM
70sGuy's Avatar
70sGuy 70sGuy is offline
AK Member
Just received a Sanyo 2050 Receiver
I'm going to set it up and test it out tonight with some JBL2600 speakers. I'm hoping that it has a good FM radio.
  #2
Old 04-24-2009, 03:05 AM
Mattwizz3's Avatar
Mattwizz3 Mattwizz3 is offline
Web-er-web user...
Pics
__________________
Never gonna buy new again!*
*(Now that Ive blown my budget)
  #3
Old 04-24-2009, 08:09 AM
chasaboo's Avatar
chasaboo chasaboo is offline
AK Member
Yeah, I've been interested in Sanyo stuff for awhile.
Pics please!
  #4
Old 04-24-2009, 11:14 AM
70sGuy's Avatar
AK Member
Sorry, I don't have Pics yet, but it really sounds good! The JBL2600s (connected to Speakers B) did'nt have quite all the bass I had hoped, but I also connected some KLH 120 as Speakers A, and using both, the unit was very impressive. It has a large volume control in the middle that goes from 0 - 100. I never got it past 10 as it was too loud. Everything seems to work OK on this Sanyo 2050, but there are a few things that I noticed that seem a little unusual. To tune the FM, I found that it was better to turn off the FM Stereo, and then to tune in the station using the tuning meter. The Signal Strength meter seems to only work on some really loud and obnoxious AM stations. Once an FM station was tuned in though, after a few seconds, the green quartz-lock light would come on indicating that the station was locked, and then I switched it back to FM stereo. This was all using the built-in little FM tube Antennae on the rear of the unit. All of the function lights seem to work, but the radio dial is not lit, not even the selector needle. I've replaced light fuses on an old Superscope receiver in earlier days, but don't know if this one has lights that need to be replaced, or if that is just the way they were made. The Power meters, Signal Strength, and Tuning meters are all lit. Did I mention it sounds great! Even the wife and cats liked it! I've read some online info (what little I could find that suggest that this receiver is 50 WPC. That sounds about right. I'll get some pics and post later.
  #5
Old 04-24-2009, 12:34 PM
70sGuy's Avatar
AK Member
Pics
Here are some pics.
Audiokarma
  #6
Old 04-24-2009, 12:41 PM
kermit z's Avatar
kermit z kermit z is online now
Loud Music saves Lives!!
Very nice looking receiver. congrates
I believe the antenna on the back is AM, but I could be wrong.
__________________
Main system- Yamaha M-70/Vincent SA-31-PHO-111/Sansui TU-717/TEAC A-3300SX/Marantz CD5004/Micro Seiki BL-21wDenon DL103Jelco750D/Boston Acoustic A400
Living Room-Onkyo M-501/KenBasicC1/Nakamichi 480/SonyCDP-CA70ES/Akai GX-265D/Pro-Ject RM1.3/Polk Monitor 10B
  #7
Old 04-24-2009, 12:51 PM
ryuuoh's Avatar
ryuuoh ryuuoh is offline
FFXIV Summoner
The ferrite bar is indeed the AM antenna. A simple piece of wire, ~3ft. will serve as an FM antenna, or you could hook up an indoor dipole.
__________________
Akai AS-970 AA-5000S
Technics SU-8080, SL-1300, SL-20, SA-5
Luxman L-80V, L-430, T-240
Yamaha NS-670, NS-690II, NS690III, T-80, T-70, M-50, C-50, CD-S700
Denon TU-800, TU-1500RD
Bozak MB80
Sansui TU-717, 9090
sun tan, drink in hand
  #8
Old 04-24-2009, 12:59 PM
PoppaSteve's Avatar
PoppaSteve PoppaSteve is offline
Your what hurts?
I was lucky enough to be able to fix a Sanyo 2033 receiver for a guy I work with a while back, and found it be a pretty good unit.
The FM section wasn't anything special on that one, but my buddy has been happy with it since it's been fixed.
Use a decent antenna, and you should be fine.
__________________
The devil take your stereo and your record collection!
The way you look you’ll qualify for next year’s old age pension!
--Adam Ant
  #9
Old 04-24-2009, 01:13 PM
zenith2134's Avatar
zenith2134 zenith2134 is offline
AK Member
Nice Sanyo. I used a Sanyo integrated amp for years and it had a great sound.
Reminds me of the Plus-55 receiver. Had one of those too, but the power switch was toast.
  #10
Old 04-24-2009, 01:53 PM
70sGuy's Avatar
AK Member
Thanks for the info about the AM Antenna. That would explain alot. I believe that I still have one of those old T wire antennas downstairs. I'll try it tonight.
Audiokarma
  #11
Old 04-25-2009, 05:34 PM
70sGuy's Avatar
AK Member
More Pics
Cut off about 5 feet of some old 300 Ohm Antenna wire, and connected, and it works much better. This morning, I took off the covers to see If I could get the radio dial to light. At first, I could find no lights for the dial, but soon found some on the sides of the dial. I looked for blown fuses, but could not find any. I even removed the bottom. I then decided to check the voltages applied to the bulbs, and when I was checking the one on the left side, they all of a sudden came on. I re-inserted the lights to the sides, and they immediately went out again. I tried jumpering around one of the bulbs, and then the right hand bulb worked as they are wired in series. It looked ok, so I went ahead ans soldered a small jumper around the non-working bulb, until I can find a replacement (the bulb will have to be desoldered anyway).
  #12
Old 04-25-2009, 09:49 PM
BrocLuno's Avatar
BrocLuno BrocLuno is offline
AK Member
Nice piece and a fun project
Funny thing is that a lot of our gear has Sanyo parts inside. Yous has them on the outside too
__________________
Broc Luno
Some Orphaned Silver
Mitsubishi, MCS, Scott, Nikko ...
A/D/S, BA, EPI, Infinity ...
  #13
Old 04-26-2009, 02:49 AM
Mattwizz3's Avatar
Web-er-web user...
The cats given its stamp of approval. The receiver looks good!
__________________
  #14
Old 04-26-2009, 06:07 AM
highping's Avatar
highping highping is offline
AK Member
Sweet picture of your cat.....congrats on getting a nice receiver.
  #15
Old 04-26-2009, 09:24 PM
70sGuy's Avatar
AK Member
The cat thinks it's her new receiver. I figured out today that the signal strength meter only works for AM, and the Tuning meter only works for FM. I don't know if other vintage receivers are like that or if it is just a Sanyo thing.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
