Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-10-2004, 01:24 PM
schlagi914 schlagi914 is offline
AK Member
Question Dynaco A-410 transformer tube amp
Hi,
has anybody ever seen this Dynaco Amp? The circuit seams to be leaned on the low output circuit for the A-410┤s, but theres one more "entry-tube" besides the driver tubes and the power transformer has the following voltages: 5V 3A, 6,3VCT 4A and 810V 220MA that differs from the circuit.
I don┤t really know the tubes that fit in, except the EL84┤s / 6BQ5 (perhaps 12ax7 as drivers as mentioned in the circuit?).
If theres anybody aut there who could help me, I would be very glad.
Thanks alot
Markus
  #2
Old 08-10-2004, 03:49 PM
Thatch_Ear's Avatar
Thatch_Ear Thatch_Ear is offline
I saw one of these on ebay once. I think the transformers were for those that wanted to design their own amps. 810V means with a center tap you have 2X 405 V going to the rectifier, so the voltage would have to be stepped down quite a bit before going to the output transformers and to the plates of 6BQ5s (300V in the RCA RT manual).
As a wag the opts probably were made to handle up to EL-34/6CA7s and if they came with the power transformer possibly 6550s as well.
Ned would know, I am just guessing.
  #3
Old 08-10-2004, 05:56 PM
Thatch_Ear's Avatar
Ryan,
You think this is a Dynaco chassis and schematic? With that kind of voltage I hope there is a choke down there in that power supply too, and yea, the caps are probably toast.
Markus,
And under chassis shot will be helpfull in seeing how many windings there are on the A-410s, and that was what I saw years ago on Ebay. If there are multiple primaries then this OPT could have been used for multiple tube types. That gives you lots of options for building something with them.
David
  #4
Old 08-10-2004, 06:16 PM
Thatch_Ear's Avatar
Found info on the 410. You can use only tubes of the voltage of the 6BQ5, so considering the sockets 6BQ5s (probably) or 6AQ8s. If you rebuild you can use 6V6s.
Link to site....lots of good info here guys, all the Dyna gear has schematics and that is just a bit of it. I hope you have Adobe. Look under Tube Data/Transformer Data.
<www.the-planet.org>
  #5
Old 08-11-2004, 12:40 AM
NOSValves NOSValves is offline
AK Member
Geezz that Dynaco transformer catalog is cool imagine buying those transformers for $20 today LOL !!
Craig
__________________
NOS Valves NBS Preamplifier l NOS Valves VRD mono blocks l Sota Jewel w/RB-300 & Denon DL-103R l Sony SCD-333ES CD/SACD l Radio X Tuner modified Sony l Modified Lascala Baby (known world wide as Frankenscala)
http://www.nosvalves.com/images/engrave2.jpg
Audiokarma
  #6
Old 08-11-2004, 01:30 AM
AK Member
Thanks for your kind help!!!
I just took some photos of the bottom of the amp. The big brown caps are 0.1mF at 1000V, the smaller ones 0.05mF at 500V.
All caps seem to be replaced once, because they are all German ones and the Amp runs 110V.
Also it┤s shure that someone had much fun in constructing a ground network.
  #7
Old 08-11-2004, 01:32 AM
AK Member
the closer down right view
  #8
Old 08-11-2004, 01:35 AM
AK Member
the blue cap down right is 50mF at 450/550V
this is the upper right view
  #9
Old 08-11-2004, 01:36 AM
AK Member
upper left view
  #10
Old 08-11-2004, 01:42 AM
AK Member
down left view.
The big blue cap is a 100+100mF at 385V just soldered together (parallel?)
If the pics aren┤t good enough I could have some more.
Thanks
Markus
Audiokarma
  #11
Old 08-11-2004, 10:46 AM
AK Member
Man trying to figure out what tubes absolutely should be used in this amp from pictures is going to be rough. Without some kind of idea what voltages are present at the tubes.
The 2 small signal tubes in the center are definitely phase splitters and of the dual triode type maybe 12AU7 or 12AX7. We needs to figure out if these front end tubes are wired for 6V heater or 12V heater. The one closest to the edge of the amp is a input amplifier tube. My bet is 12AX7 input amplifier one half for each channel and 12AU7 phase splitters.
Now the output tubes are almost positively EL84 wired in UT but the UT taps are not directly connected but run through 10 Ohm resistor. Not sure of the bias setup it looks like all the cathodes are wired together and then the wire heads toward the front of the amp and I couldn't make out where it going. This is pin 3 of the output tubes physically trace it and let us know where it goes.
I'd replace all the coupling caps and under chassis electrolytes for starters. Bring it up on a variac once the proper tubes are a known fact and see if the above chassis cans survive. I myself would just replace them.
I bet this could be one great sounding little power amp once working up to snuff.
This really doesn't look like a home built amp to me. If it was the builder was very good.
Craig
__________________
  #12
Old 08-11-2004, 04:27 PM
Thatch_Ear's Avatar
I like that huge dropping resister with the slide. You can see both the OPTs B+ running from it. No chokes though and the PS is a bigun.
  #13
Old 08-11-2004, 05:03 PM
AK Member
Oh wow that does slide doesn't it ! Pretty cool never seen that before have you ?
Craig
__________________
  #14
Old 08-11-2004, 05:20 PM
Thatch_Ear's Avatar
Yes and much larger. Here is a 100 watt, 100 ohm with a slide on the OPTs of a Fisher 400 for scale.
  #15
Old 08-11-2004, 08:43 PM
AK Member
Thatch,
You wouldn't happen to have a extra variable resistor like that would you ? I know someone that needs something like that for there power center channel on a EICO ST70. It calls for a 50 Ohm 50 watt Variable. Of coarse I would pay you whatever its worth and shipping.
Craig
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
