I've finally gotten some available time, and scored the the 2nd (used, hopefully good) NMA1012 output that I needed to replace the incorrect NMA1216/NMC1216 transistors that are on one channel of this amp, so it is time to dive into a pretty complete refurbishing.
So, I have some of probably many questions to come regarding this project.
First, does anyone have any suggestions on replacements for the the 80v 220uf and 470uf caps that are on the PSU and Driver boards. The originals (and they are definitely original because there is a ton of severely deteriorated glue where they are mounted) are Nichicon, light blue case, no series marking.
Digi-Key seems to only have SMD and a couple of snap-in devices in these values; Mouser has a couple of radials- the Nichicon PM and United Chemi-con KZE, but not being the normally recommended Panasonic or Nichicon caps I'm hoping someone has some suggestions.
I guess it is also possible to slightly upgrade the voltage or capacitance values to widen the choices, but I am a little too uneducated to start guessing at suitable uprating amounts. Which actually brings me to my next question-
This amp has been used, and will be put back into a system driving some pretty uncooperative speakers- Infinity Renaissance 90's. Beyond the the 4ohm rating on the speakers and driving them from an amp rated for 8ohms, the Watkins woofers present some drastically low impedances and current demand. So although there seems to be no real consensus about replacing the main caps when people do a recap, I figure that now is the time to replace these 30 year old caps.
The direct replacement would be the Nichicon KG 63v 15000uf that only seems to be available from Michael Percy, but I am seeking the collective wisdom here about possibly upgrading to a higher capacitance and voltage to improve the power reserves. Also, I am not planning to get silly about "boutique" components, but I would like to hear any opinions about other available caps. This is a pretty rare and fantastic sounding amp, so I am interested in getting high grade parts into it and am willing spend some money to do so. There seems to be some popularity for Siemens, Philips and others that that have caps in these ranges, but sometimes it is hard to differentiate between solid, high-quality components and the exotic fringe.
And finally for today, I will replace the notorious "black flag" caps with silver micas as Echowars suggests, but I am wondering if I should also use the micas to replace the other "styrol" polystyrene caps on the driver board. In addition to the "black flags," there are also 200, 680, and 1000pf polystyrene film caps. I picked up a handful of 22pf mil-spec (I believe) CM05 Cornell Dubilier silver micas at All Electronics in Van Nuys the other day to replace one value of the "black flags." Unfortunately, they were closing so I didn't really get a chance to browse for other values, but they were inexpensive at 3/1.00, so I was thinking that if they had the higher values they might be a good candidate to replace the other styrol caps. Is it worthwhile to replace the ones that aren't the "black flags," and also, just out of curiosity, what is the difference between the construction of the "black flag" polystyrene and the polystyrene film caps. Their designation is the same in the schematic.
So, my apologies for this long-winded post, and thanks in advance for any help and suggestions. Herb
