OK! Here we go.
You've probably at some point in your life run across some minimus-77 speakers that were pretty cheap and though to yourself "I'll just refoam them and see what happens." However to your dismay you can't find anyone with surrounds that work. So you're screwed unless you buy into one of those expensive "upgrade kits" which has you changing crossover components and installing a new woofer....
I say f$*& that! Here's how to do it:
The dimensions of the woofer are indeed strange. The required surrounds have to have an ID of 2.6 and an OD of 4.75, which simply do not exist (are the manufacturer's listening? --doubtful)
Since they don't exist, you have to make them. This is done by affixing two surrounds together of different sizes. Here's what you need:
The smaller surround should have an ID of 2.5-2.6" and an OD of 3.875"
The Larger surround should have an ID of 3.5" and an OD of 4.75-4.8"
The two combined produce the correct surround and still allows for proper excursion and support. You'll have to hunt around for the surrounds between various suppliers but the surrounds do exist. If you have a speaker repair business, you're probably familiar with MWA speaker parts, but they only sell to repair businesses.
On with the repair:
1. Clean off all the old surround crap from your woofers. This can be done with a knife, solvent, or whatever you chose. I would personally stray from chemicals because the soften the cone and smell terrible. You can remove the old cardboard trim ring if the glue is coming loose, but if its tight, it provides a more even adhesion surface for your surround. The glue that "simply speakers" sells is really good, and "global adhesives" surround dampener is good glue as well - it just takes much longer to dry. I wouldn't recommend Elmer's or tacky glue here. It didn't work well at all under high excursion.
2. Apply a bead of glue to the top of the outer edge of the smaller surround. Now lay the larger surround on top of the smaller surround. Tamp the two together until the glue gets tacky. Allow it to dry overnight before going any further.
3. Apply a bead of glue to the back of the cone where the surround will attach. carefully work the inner lip of your surround and make sure it evenly contacts the cone and glue. Tamp it down until it gets tacky, then wat a few hours for the glue to set.
4. At this point you notice something. The outer lip of the surround you made sticks up about 3-5mm from the basket. You're going to find it tricky to keep the surround glued to the basket while the glue dries unless you shim the woofer..
5. cut 90% of the dust cover away so you can easily re-attach it. At this point you need shims. Old photographic film is a great source here. Cut off the feed holes, and cut lengths about 1.5" You'll need six total. Fit the 3 pair of 2 lamination film in a delta formation and you'll have the VC perfectly centered while still allowing you to move the cone down slightly while you attach the surround.
Continued in the next post.....
