Good! I was planning to do that, but good to confirm.Pilot hole ? Center punch first then drill a 1/8" hole to guide the hole saw to keep it from "drifting".
Your best advice here, teeth and bits filled with aluminum really ruins your day.If you cut too fast it may clog up the teeth of your bit.
Carl
Can you expand on that a bit? I don't know squat about what you just said... :stupid:Not me ..I'm using and offset end mill cutter.Plan on using a milling machine to fabricate the entire plate of .250" aluminum plate.
