Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-19-2004, 09:39 PM
henter04 henter04 is offline
AK Member
Teac 6010 GSL problem
I have the Teac 6010 and it was working good till recently. The problem is during rewind or fast forward the reels are not fully synchronized anymore that one would still be spinning while the other one is at complete stop thus creating a big mess with the tapes. What can be the problem? Thanks for all the help.
  #2
Old 08-19-2004, 09:53 PM
Vintage TX's Avatar
Vintage TX Vintage TX is offline
Analog forever
Could be the brake-solenoid or the actual brakes.
When you use Play function, does the tape slack and tension-arms bounce at the same time ?
Each reel-motor has a brake-solenoid mounted below the motor, check for loose brake-pad, or worn down brakes.
Don't adjust the actual solenoid, before you have determined what the problem is, even if those adjusting screws seems tempting to mess with.
Take the black back-cover off first and see what's going on.
Good Luck and let me know what you find.
  #3
Old 08-19-2004, 10:00 PM
Vintage TX's Avatar
Analog forever
Reading your post again, is it doing this when the tape is spooled up on either right or left reel and the deck does not come to a final stop when the tape is ended ?
  #4
Old 08-19-2004, 11:27 PM
AK Member
Vintage TX, yes it does it everytime I go on fast forward or rewind on either side. If I just leave it on play it seems to be OK except if I try to reverse the direction while playing, then there's some slack on the tape and it won't go on play cause the tension arm is not engage anymore. But if i just let it play, it would till the end of the tape. Anyway thanks for the response and hopefully I can find out what's wrong with it.
  #5
Old 08-19-2004, 11:53 PM
Vintage TX's Avatar
Analog forever
Seems like you have 2 problems.
If the tape tension slack when reverse play is engaged that can be the brakes on each reel-table motor is not responding correctly.
When you rewind the tape, does the right reel-motor still spins after all tape is on the left reel ?
Tension arm falls down correctly ?
Sorry for all questions, but these can be tricky
Audiokarma
  #6
Old 08-20-2004, 05:40 PM
AK Member
Vintate TX, yes the reel still spins after all the tape is on the left side. And yes I believe the tension arm falls down correctly. By the way, where exactly are the brakes located? Thanks for the help Vintage TX.
  #7
Old 08-20-2004, 06:03 PM
Vintage TX's Avatar
Analog forever
You welcome.
Which reel still spins if you have used rewind,
the right one or the left ?
  #8
Old 08-20-2004, 07:15 PM
AK Member
The right one still spins after using rewind. Maybe like you said, needs brake adjustments or maybe more serious than brakes adjustment. Oh well...
  #9
Old 08-20-2004, 07:55 PM
Vintage TX's Avatar
Analog forever
OK, that is not the brakes
Behind the right tension-arm is two switches when the arm drops down,one of the switches shut the power off to the reel-motors when tape is spooled up completely to the left reel.
These are hard to reach but take the back-cover off and look just behind the tension-arm from the back, you should be able to see 2 small switches and a tiny spring kind of wrapped around.
You can also take the right sidepanel off to get more room.
Of course unplug the unit first.
Hopefully you find a loose wire, or in worst case a broken switch in two pieces..
Good Luck !
  #10
Old 08-23-2004, 08:48 PM
AK Member
Vintage TX, thanks for all the help. Anyway since the reel tape is like a 2 piece unit I took the upper part off the main wooden case and check the switches and found no loose wire or broken switches. Now what it's doing is, everytime the tape is on play, and I stop it I noticed that the take up reel is always the one that stops first and it does it on either direction. By take up reel I mean the spool that the tape is going into. Thanks again and maybe I need to adjust the brakes now.
Audiokarma
  #11
Old 08-23-2004, 08:52 PM
AK Member
Vintage TX, thanks for all the help. Anyway since the reel tape is like a 2 piece unit I took the upper part off the main wooden case and check the switches and found no loose wire or broken switches. Now what it's doing is, everytime the tape is on play, and I stop it, the take up reel is always the one that stops first and after about 5 seconds the supply reel stops and it does it on either direction. By take up reel I mean the spool that the tape is going into. Thanks again and maybe I need to adjust the brakes now.
  #12
Old 08-23-2004, 08:57 PM
Vintage TX's Avatar
Analog forever
So my guess what's wrong with the "patient " didn't work.
Did it change trouble now to the other reel instead ?
Before the R-reel just kept on going after rewinding the tape, correct ?
  #13
Old 08-23-2004, 09:49 PM
AK Member
Your right Vintage TX. Anymore suggestions before I put it in the closet? Thanks again.
  #14
Old 08-23-2004, 09:55 PM
Vintage TX's Avatar
Analog forever
But when you had it apart to check the right tension-arm, does the motor come on/off properly when you lift and release the arm ?
Don't give up yet.
  #15
Old 08-23-2004, 09:59 PM
Vintage TX's Avatar
Analog forever
Let me ask this:
If you press play and the left reel has tape on it, and feed the take-up reel, "normal Left to right"
When pressing stop does the R-reel stop directly and the L-reel still keep on feeding the tape or ?
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
