Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 06-17-2009, 07:44 PM
atrac atrac is offline
AK Member
Coral BX-1001's
Does anyone own some Coral BX-1001's? I'm curious as to what you think of them. I saw a pair at the local SA for $21.50 each. Seems a little high, or not?
Unfortunately it looks like the grills are stapled on so I couldn't even examine if there's foam rot or not (or if they are even foam?).
Thanks!
  #2
Old 06-17-2009, 11:32 PM
Thespeakerdude8's Avatar
Thespeakerdude8 Thespeakerdude8 is offline
AK Member
yeah, a little high. Think Sansui sound. They don't usually have foam, usually pleated paper surrounds on the mids and cloth on the woofs.
1001's if I am not mistaken have a 10" woofer and a kabuki collection of mids , tweets, and supertweets.
  #3
Old 06-18-2009, 12:35 AM
gearhound's Avatar
gearhound gearhound is offline
AK Member
As far as I know.....they have the same driver configuration as my 3-way Coral BX-801's.....except using a 10" woofer instead of an 8".
My 801's didn't have much bass response, very forward mids, but a quite nice high end, coming from a pair of good quality alnico horn-loaded tweeters.
Steve
  #4
Old 06-18-2009, 01:14 AM
highping's Avatar
highping highping is offline
AK Member
Thanks!
Don't be so shy. Put the speakers in your cart and take them into the kitchen ware isle. Grab a butter knife, a sturdy fork, and have at her! Did that with the last pair of speakers I picked up at GW (Fisher XP5's). There's nothing wrong with inspecting something you intend to buy.
  #5
Old 06-18-2009, 08:40 AM
pilotputz's Avatar
pilotputz pilotputz is offline
AK Member
The 1001s are a 3 way speaker with a 10" woofer, paper mid and small horn tweet.
I always liked the sound of Coral speakers. They are Japanese and very efficient and sound great with tubes.
With that said, 20 bucks a speaker is a bit steep in my opinion.
Audiokarma
  #6
Old 06-18-2009, 08:53 AM
Scuzzer's Avatar
Scuzzer Scuzzer is offline
Fixed Bias
Quote:
Please don't do this. There are 4 small philips screws holding the grill on, one in each corner. With the screws removed the grill just pulls off. Some jacknob did that to the set I picked up at the local thrift and it was a pain to fix the damage.
I like the efficiency of my set of BX-1001's but they do roll off pretty quickly below 70hz. I use 2 pair stacked at my solar powered cabin along with a tripath based amp and you can't beat the combo for power draw vs. volume vs. cost. However, they should be $21.50 for the pair not each.
  #7
Old 06-24-2009, 12:20 AM
AK Member
I found that I had a 50% off coupon for SA, so I went back today and found the Coral BX-1001's were still there. Unfortunately, the goons had gotten to them -- the grill on one of them had been partially ripped off the staples. I was able to find the holes the staples made and push the grill back on nice and tight. I could see the aforementioned screws, so I'll know how to get in there if I ever decide to.
So yes, I did buy them. They are SO heavy...had to carry one at a time! It's interesting because each time I walked out with one, a different person commented on "how nice those speakers are!"
As pilotputz has said, they inded are a 3 way speaker with a 10" woofer, mid and tweeter.
So...how do they sound??? I have to admit, my expectations were high -- and not fully met. These speakers have really really nice sounding highs and lows, but the midrange is a bit soft. I listen to the same music I always do when I test speakers and the midrange is definitely lacking. I hear sound coming from each mid so I don't believe they are blown.
On the back there is a knob for "Tone Control" with decrease, normal, and increase settings. I have tried it with normal and increase and the latter only seems to boost the base even more.
All of that being said, I do like them. I spent several hours auditioning them this evening. The more I listened to them, the more I liked them. They do sound different than anything I've ever heard before. And dare I say, they have a "vintage sound" quality to them. I kept thinking of watching movies in theaters back in the 80's. I listen to movie scores and that feeling kept coming into my head as I listened. The age before Dolby Digital! Does that make sense? Thespeakerdude8 mentioned "Sansui" sound. How would one describe that?
Also, the front grills have areas that are dinged, so the wood appears lighter than the rest. I was thinking of using some brown shoe polish to touch it up -- I'm too cheap to buy wood stain right now.
  #8
Old 06-24-2009, 12:37 AM
Scuzzer's Avatar
Fixed Bias
I dabbed some old stain I had around here on the grill dings but shoe polish should work as well. IIRC there are only two 1 uf caps for each speaker and since all the drivers are 8 ohms that makes the crossover point 10k. I'd replace the two caps and get some deoxit on the rear switch and see what happens. If that doesn't work go on two stage two.
My lows and midrange were all screwed up when I got my first pair. Everything smoothed out quite a bit when I softened up the woofer surrounds with some Meguiars rubber conditioner. I removed the grills, laid the speakers on their backs and with some music very softly playing through them I spread the Meguiars on the surrounds (don't get it on the paper cone) with a 50 cent small foam paint brush.
Alternatively, you could just try to loosen them up with loud music for a few days. Wire one speaker out of phase, put them face to face and throw a big thick blanket over them and pump some tunes through them.
  #9
Old 06-24-2009, 12:47 AM
Scuzzer's Avatar
Fixed Bias
To add a little more, my tone control on the back works exactly as described. decrease=normal american speaker, normal=somewhat in your face japanese sound, increase=jab your ears with high frequency icepicks. YMMV depending on where and how they're set up and your personal preferences.
When I had them set up in my normal listening room I couldn't possibly think of a use for the increase setting but now that I have them in my sound challenged unfinished cabin I generally use that setting to balance out the exaggerated lower frequencies.
  #10
Old 06-24-2009, 12:52 AM
AK Member
Thanks for the tips, Scuzzer! I think the next obvious step for me is to try the "decrease" setting. Can I make that adjustment while the sound is playing or should the receiver be completely off first? *EDIT* Decided to play it safe and make the adjustment with the receiver off. And that did it -- now they sound fantastic at the "decrease" setting. It was the proper balance I was looking for! I guess the American sound is what I was looking for! If only I had tried this before I posted my initial review!
I just tried the brown shoe polish and it worked fairly well -- but never-the-less wood stain seems to be the best choice. The brown wasn't dark enough. Cheapskate I am!
Audiokarma
  #11
Old 01-28-2011, 11:08 PM
markshan's Avatar
markshan markshan is offline
Garbage picker
Try new caps and see how it goes.
__________________
I know just enough to be dangerous.
  #12
Old 01-29-2011, 12:03 AM
boreas's Avatar
boreas boreas is offline
Let The Boy Boogie Woogie
Is anyone else thinking Coral may have been Radio Shack's supplier for some of the Nova series with screwed on grilles and hot chocolate paint on the rear baffle?
John
__________________
Addictive Personality
C:\JB Graphics\Multi-Logo4xs.jpg
  #13
Old 01-29-2011, 02:24 AM
Teradacto58's Avatar
Teradacto58 Teradacto58 is offline
AK Member
Just walked in the door with a pair of BX 1001's.....VV in Bellingham,Wa. sold them to me for $14.95/Pair. Boxes pretty good...just one front dinged top corner.....repairable! Woofers are a lil' dusty.....Gonna give them a try.... Well they sound grea!t.....Nice vintage sound!!! Ran My $40.00 Realistic STA-2290 into the Corals....
This works great because it also has a midrange adjustment!
ZZ Top sounded Sweet!!!....as did The Hollies!!!!!
__________________
Yamaha M-80,Onkyo TS-SR600,Empire 208,Dual 1225,501,Philips CD204, Sony TC-765,Cambridge Audio R50's,Celestion 25's,15XR's,Tannoy Mercury 2,JBL L36
  #14
Old 01-29-2011, 08:50 AM
Vintage_Hi-F's Avatar
Vintage_Hi-F Vintage_Hi-F is offline
Vintage Audio Geek
Quote:
Actually it's the other way round, most (1960's any ways) sansui speakers were rebaded Coral's.
__________________
AR9LSi's
Sansui 9090DB
Sansui SR717 TT
Sony TC-K777
Shure D6000E
AudioSource EQ-One
  #15
Old 01-29-2011, 10:48 AM
erocksteady erocksteady is offline
AK Member
WHAT?! Dude!! You totally just stole these right out from under me! I'm just kidding...all is fair! (Especially seeing as how you don't know where I live, ha ha).
Check out my post from last night in Dollars and Sense:
http://www.audiokarma.org/forums/sho...d.php?t=347637
Last edited by erocksteady; 01-29-2011 at 11:06 AM. Reason: To ensure it's clear I was kidding ;)
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
