Speakerlab Seven restoration
Sir.Byrd
Lunatic Member
Before:
All pictures linked here:
http://www.audiokarma.org/forums/showpost.php?p=2894178&postcount=30
http://www.audiokarma.org/forums/showpost.php?p=2894186&postcount=31
http://www.audiokarma.org/forums/showpost.php?p=2902493&postcount=63
http://www.audiokarma.org/forums/showpost.php?p=2905386&postcount=77
http://www.audiokarma.org/forums/showpost.php?p=2905773&postcount=80
http://www.audiokarma.org/forums/showpost.php?p=2924280&postcount=130
http://www.audiokarma.org/forums/showpost.php?p=2924286&postcount=131
http://www.audiokarma.org/forums/showpost.php?p=2924293&postcount=132
http://www.audiokarma.org/forums/showpost.php?p=2924965&postcount=135
http://www.audiokarma.org/forums/showpost.php?p=2934113&postcount=165
http://www.audiokarma.org/forums/showpost.php?p=2935042&postcount=177
http://www.audiokarma.org/forums/showpost.php?p=2952397&postcount=202
http://www.audiokarma.org/forums/showpost.php?p=2952399&postcount=203
http://www.audiokarma.org/forums/showpost.php?p=2952402&postcount=204
http://www.audiokarma.org/forums/showpost.php?p=2952404&postcount=205
http://www.audiokarma.org/forums/showpost.php?p=2955660&postcount=215
http://www.audiokarma.org/forums/showpost.php?p=2955663&postcount=216
http://www.audiokarma.org/forums/showpost.php?p=2955666&postcount=217
http://www.audiokarma.org/forums/showpost.php?p=2999946&postcount=264
http://www.audiokarma.org/forums/showpost.php?p=3003317&postcount=267
http://www.audiokarma.org/forums/showpost.php?p=3008008&postcount=275
http://www.audiokarma.org/forums/showpost.php?p=3010441&postcount=285
http://www.audiokarma.org/forums/showpost.php?p=3013621&postcount=290
http://www.audiokarma.org/forums/showpost.php?p=3027716&postcount=304
http://www.audiokarma.org/forums/showpost.php?p=3028283&postcount=305
http://www.audiokarma.org/forums/showpost.php?p=3032673&postcount=317
http://www.audiokarma.org/forums/showpost.php?p=3035702&postcount=324
http://www.audiokarma.org/forums/showpost.php?p=3041232&postcount=331
http://www.audiokarma.org/forums/showpost.php?p=3041245&postcount=332
http://www.audiokarma.org/forums/showpost.php?p=3064020&postcount=373
http://www.audiokarma.org/forums/showpost.php?p=3410636&postcount=414
http://www.audiokarma.org/forums/showpost.php?p=3411861&postcount=422
To do:
  1. Repair grill frames DONE
  2. Recloth grills (JBL blue) DONE
  3. Brace baffle further with 1" dowels DONE
  4. Strip and replace all veneer DONE
  5. Repaint baffle DONE
  6. Switch T350 tweeter to front mounting N/A
  7. Remount drivers with T-nuts and plywood shims DONE
  8. Paint midrange horns (?) NOPE
  9. Replace caps and resistors in crossover DONE
  10. Bypass L-pads DONE
  11. Figure out damping, possibly replace fiberglass insulation with something else DONE
  12. New binding posts DONE
  13. New internal wiring (up from 18 awg) DONE
We are painting the midrange horns to match the JBL blue grill cloth.
By the way, did you order the cloth?
Soon, I'm busy stripping all the veneer off today, you are lucky you do not have to do this work, it sucks! but it is better this way.
Are you sure you want to do that? I mean it is a big job to strip all of it off of those speakers.
But it is better this way, we can get done sooner with the restoration.
Are you going to fluch mount the woofers as well? Looks like a healthy rask ahead of you! Those look like Old EV cabs you have there- hope it all turns our well for you!
DC
DC
The woofers are already flush mounted. they might stick out a little more with the gasket tape, but I do not want to cut into the MDF any more because it will loose strength.
Don't worry, I can do it myself, there is enough to do that I want to get as much done as possible this week.
Good news, the veneer will be cheaper than I thought. We will only need 25 square feet, and the sheet of veneer only needs to be 20" wide.
I want you to look up veneer types and post what you think would look good.
I was thinking dark walnut stained redish, just like the JBL L19s.
I forgot to say there is a 1 inch wooden dowel in the cab bracing the front to the back of the cab.
Okay, I will look up veneer types and post what I think looks good.
Given the weight of all those drivers I would certainly add more bracing! I was also thinking there was an upgraded diaphragn for the T350 as well!
DC
Weren't we going to brace the second dowel where the controls use to be?
That is a weak area there.
Yes, going to do one there, and then reassess after that.
The plywood blanks that I am going to use for the T-nuts might add some more strength as well.
DC
Yup. Surprisingly the 12" woofers weigh a little more than 10# each, and the 10ers about 6 or 7#
I'm pooped! I have 3 out of 12 sides striped of veneer and my hands are already cut up!
You owe me Laith!
You should repay me for my work with getting my JBLs reconed!
I'll repay you Will with helping you get your RSIIIs refinished and finished.
You've had them disassembled for 5 months now.
How come you are removing the original veneer? From the pics it looks like it's in pretty decent shape....no?
Looks like a neat project.
Mike
The original veneer is actually pretty bad. Part of the veneer on the back is gone, and is bad in some areas.
