Baby JBL Refinish
MAXZ28
Addicted Member
Another weekend project complete....
These L15's were in really great original condition but the tops and bottoms were full of impression scratches and the wood on top was stained as well. You can see the major blemishes easily in the second photo. The woofer surrounds were shot too.
Knowing how thick the veneer is on these things I thought it would be a worthy refinish project without risk of burning through the veneer. So out came the Korner Kat and some 150 grit sandpaper for the initial sanding and a followup second block sanding with 220grit.
Wiped everything down thoroughly with mineral spirits and applied three coats of Watco's Danish Oil Natural over the course of the weekend.
In between coats, I refoamed the woofers.
They now look virtually out-of-the-box new and sound incredibly nice for their petite size. These are herd keepers for sure. :yes:
With all the veneer imperfections addressed, I decided to protect the refinished veneer by applying some felt feet'cha-ma-call-its to the underside. I'll let the finish cure a few days more before I smooth it out with some steel wool and then I'll use some Howard's Feed-N-Wax to buff and shine it to a beautiful luster.
:thmbsp:
I have a pair of L16 & L19 needing the same treatment.
EDIT: Did the surround glue to the backside of the cone?
Scott
Lookin' sexy. What's the finish like after using a product like Howard's Feed-N-Wax? Is it sticky? Can you pick it with your fingernail? I've oiled before, but never finished with any of the wax. I have some sitting in my closet waiting for me to become bored again.
Very nice refinish job! As far as johnnm's question, the wax is very thin. The wax I've used was almost like glass to the touch when I was finished. Not sticky at all.
Beautiful! Do you know how the Danish oil differs from tung oil? I usually use tung oil on my projects but that Danish oil has a wonderful finish.
Nice job! :thmbsp:
I've got a VERY similar set of 4401s in line for the same treatment (though I tend to stay with the JBL-ratio turpentine and linseed oil). After that is some L20T3s that are getting a new cherry veneer.
By the way, my 4401s sound great with 033 tweets in place of the 034s (just a little level padding needed).
je
Nice job! :thmbsp:
...(though I tend to stay with the JBL-ratio turpentine and linseed oil).
Is this a super secret trademarked formula or do you care to share? :scratch2:
I have some L26's and L36's sitting in the garage next in line for a refinish and I'd love to try something as close to factory as possible.
