Helmuth
Hi People,
At my introduction I told that I yust started to repair a WEGA V4810 V-fet amplifier similar to the TA-5650 of sony. And many asked me to start a topic about it.
I discovered the TA-5650 by a Dutch audio enthusiast (Jerry) and I respect his electronic knowledge so that had to be a interesting amp.
I did some research and discovered the V-fet technology. The V-fet is the solid-state variant of what comes the closed to the the triode tube. And it is a kind of power J-fet. The preamp is a J-fet type :thmbsp:
A triode tube can amplify audio whit low distortion without negative feedback.
You shout not confuse the V-Fet whit a Mosfet. The V-fet is junction fet so there is a gate current and low Cgs different to the Mosfet, where almost no current flows types how have a large Cgs witch makes them frequency dependable.
So I would like to have a nice vintage set of the 70-80 the period where the audio equipment reached its peak. Knobs switches filters VU meters for lovers of technique a great time. People would spend a lot money on a good set.
I wanted a nice vintage set to have beside my Yaqin tube amp and stuff I build my self.
So I started looking on marktplaats a popular second hand market site in the Netherlands.
And I found the WEGA V4810 problem it was defective. I am a professional electrician so that was not the problem I searched for new NOS -Vfets and found them in china. So I bought the defective WEGA V4810 and it was black that i like most
After a while it turned out to be in a very bad state, all V-fets defective and all transistors replacement types. In the Netherlands we say how says A have to say B, what says when you start something you have to finish it.
I also have support of Jerry how also repaired a TA-5650. I found some great info on Karma. And got a tip from Piet a other Dutch guy on karma.
Here a picture of my amp.
At the same time on marketplace the tuner how fits to the V4810 :tresbon: I couldnt believe my eyes. I had to have that one to also I found a very cool tape recorder but do not use that stuff butt looks impressive.
Here the pair after I cleaned the outside.
Nice links
http://www.passdiy.com/pdf/ZV8_power_jfet.pdf
http://www.thevintageknob.org/VFET/VFET-main.html
. After a while it turned out to be in a very bad state, all V-fets defective and all transistors replacement types. In the Netherlands we say how says A have to say B, what says when you start something you have to finish it.
Nice links
