Leave it in the AC position.
I have a 170 DC amp, 3250B pre, and a 2110 tuner. From my owners manual:
DC Coupling & AC Coupling Switch
This switch is provided to protect Model 170DC from large output popping noise due to erroneous connection of expensive speakers, troubles of preamplifier or using a preamplifier not designed for DC amplifier.
Therefore, whenever there are possibilities of the above cases, please set this switch to the AC COUPLING position.
Since I have the matching pre amp, I have it set at the DC position like slomar and have had no problem. I think slomar and I have it right. If your pre amp is not designed for a DC amplifier, you may want to leave it on the AC position.
....but I could be wrong...
at all. In fact, Marantz used capacitors that withstood the passage of time pretty well.a crappy standard cap
We are in complete agreement there! Also, I should mention that I agree that many service grade "capacitor testers" do not properly test a capacitor, and that is what I think you were getting at. In general, it is safer to say that a 20 year old capacitor is bad on average if you consider all brands. I just happen to have found that in Marantz equipment, that isn't always a safe assumption. Yeah, I actually test them and put the originals back if they test better than the new ones. It would be easier to simpler replace them all.Anyway - nothing makes a bigger difference than the right part. Not the most expensive.
