Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Vintage Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-25-2009, 10:07 PM
jayk's Avatar
jayk jayk is offline
<Akai GX-630D-SS
Jvc r-x400 receiver, display out ?
anyone know anything about the front panel displays on these things. i don't know if it's LCD, florescent, LED, ?
receiver worked fine last time i used it (~2 years ago?) except for the display.
is there a cheap easy fix?
there is a battery compartment on the back panel. what is that for-tuner memory?
thanks!
  #2
Old 08-26-2009, 12:27 PM
ryuuoh's Avatar
ryuuoh ryuuoh is offline
Resident FFXI Red Mage
Display out could be the supply voltage, or if it's a VFD (vacuum fluorescent display) it could be worn out.
Battlery is for memory presets.
__________________
Yamaha NS-20T NS-670 NS-690 II NS-690 III M-50 C-50 T-80 T-70
Denon TU-800 AVR-786 AVR-2500 AVD-2000
Sansui TU-717
Luxman L-430 T-240 L-80v
Technics SU-8080 SL-1300 SL-5
Beware Metropolis
Amon Duul II Made in Germany
  #3
Old 08-26-2009, 03:44 PM
markallen's Avatar
markallen markallen is offline
Luddite Tendencies
Chances are VERY good that the fuse lamp behind the display is burned out. I have this receiver, and this is what happened to mine (also to an R-X300 I owned briefly). MAKE SURE you get the EXACT same rated replacement. When I replaced mine, it was a slightly different milli-amp rating, and that thing got HOT! Could have damaged the board the bulb was clipped to.
The bulb may be behind some tin reflective shields that must be removed to get to it, can't remember exactly. But if you open it up it should become obvious. It's not a difficult fix.
  #4
Old 08-26-2009, 07:30 PM
jayk's Avatar
<Akai GX-630D-SS
thanks for responses guys. i'm just remembering that the display failed in 2 or 3 sections, each spaced a few days or a week after the first. iirc, first was the spectrum display, then the next 2, a few days apart.
don't know if that helps or tells you anything. ?
i should say, i'm only a layman with zero experience fixing these things. i may just use it as is, give it away, or ?
  #5
Old 08-27-2009, 10:51 AM
markallen's Avatar
Luddite Tendencies
Quote:
Originally Posted by jayk View Post
thanks for responses guys. i'm just remembering that the display failed in 2 or 3 sections, each spaced a few days or a week after the first. iirc, first was the spectrum display, then the next 2, a few days apart. don't know if that helps or tells you anything. ?
You can do this. No soldering! I pulled the cover off my '400 (6 screws, 2 each side, 2 in back) and took a photo, which I've attached. Of course you can't see the lamps in this photo because they're on the other side of the board.
There are 9 metal tabs that keep the lamp board attached to the tin reflective housings. There are 4 tabs on the R end, 3 in the middle, and 2 on the L (as seen from the back - some are obscured in the pic by cables). These must all be bent straight out so the board can be slipped off. It will still be attached by a power cable, so you won't actually be removing it from the receiver. You will see 3 fuse lamps. Replace them, and then replace the board as it was. This should do it.
It's difficult the use the receiver if the screens are dark, so I encourage you to go for the fix. Not sure where you can get the lamps, but again MAKE SURE they have the exact ratings of the ones you remove. The wrong ratings raise heck with the diodes on the lamp board.
Audiokarma
  #6
Old 08-27-2009, 11:45 AM
jayk's Avatar
<Akai GX-630D-SS
you make it sound so easy!
i'll give it a shot but probably not til some snowy day this winter.
right now it's just stashed away as i use other amps for my ht/music av systems.
i'm bookmarking this thread for future reference.
and thanks guys.
  #7
Old 10-30-2009, 08:32 PM
jayk's Avatar
<Akai GX-630D-SS
Jvc receiver now back in use after 2 years 'dormancy'.
using R-X400 to replace one of the 2 pio qa800as (see slideshow below) that are getting de-hissed.
both went in for de-hissing/de-crackling today.
one is hissy/crackly in left front channel, other is same in right front channel.
they both still work well but for above issues. been using them right along.
scott f, of audio fixation, will have them back in form in no time.
met him this afternoon at local gas station and transferred amps to his vehicle.
r-x400 worked right off and sounds very nice!
edit-display not yet fixed. very low priority.
  #8
Old 11-02-2009, 02:45 PM
Tinitus's Avatar
Tinitus Tinitus is offline
I got nuthin'.
Thanks for this thread, guys!
I use a R-X500 on the computer for needledrops. The part of the display that shows the volume bars and sources blacked out about a year ago. I was sure that this was some obscure fluorescent screen and didn't want to mess with it. I can still read it with a flashlight. Now I think I'll try new bulbs.
AK is great!
Bob
  #9
Old 11-02-2009, 04:20 PM
jayk's Avatar
<Akai GX-630D-SS
AK is great!
Bob
let us know how new bulbs work out.
  #10
Old 11-02-2009, 04:27 PM
SpruceMoose SpruceMoose is offline
AK Member
i fixed one the other day for my sister-in-law. the fuselamps were OK, but the light array was not getting any power from the main board. so........ i unplugged the connector from the main board, found a wall-wart of the correct rating, plugged it into the outlet on the back of the receiver, and ran the wires in through the back panel. then i crimped the wires from the wall-wart to the pigtail from the light array. voila! lights for the front panel!
__________________
custom double new large advents
B&O3300/MMC3+5/Dual 1245/M97xE+M91ED+680EE/PAS2/FM1/ST70
Audiokarma
  #11
Old 11-11-2009, 10:05 AM
HomeBody's Avatar
HomeBody HomeBody is offline
-Less Is More-
Quote:
[Raises Hand]
Uh...Would Ya Mind Running that by Me Again...??
  #12
Old 11-11-2009, 10:34 AM
PacificStereo's Avatar
PacificStereo PacificStereo is offline
Raving HiFi Fanatic
Kamakiriad! What a great record.
He means that the display lamps for some reason (apparently he does not have access to a schematic) were not getting power, so he powered them externally with a small AC adaptor.
Those displays are reverse-polarized LCDs (light characters, dark background) and are backlit with fuse-style lamps.
I used to find bad solder all over those boards, so you might consider looking for that, especially at connectors. Probably all you need to do is replace those lamps. Getting the assembly apart isn't that big a deal.
__________________
Welcome to Pacific Stereo!
Pacific Stereo, 1961-1986. I remember, and I keep the blue flame lit!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
The Tube Store
Grant Fidelity
AudioClassics
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
TR Audio
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
Politicalchat.org
Yesterday's Audio
Zebra Cables
Radio X
MCM Electronics
Videokarma.org
Avanti Audio
esmokers.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
