Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-27-2009, 09:37 AM
ToasterBin's Avatar
ToasterBin ToasterBin is offline
Toasterbin
Anybody know anything about vintage Toshiba receivers?
In particular, the SA-520, which I've been unable to find much if anything about. Looks to be a solidly built unit, so I am going out today to take a listen.
Your thoughts are appreciated.
ToasterBin
  #2
Old 08-27-2009, 12:35 PM
nickv41's Avatar
nickv41 nickv41 is offline
AK Member
I have an SA-725 doing garage duty. Built like a tank. Very reliable. All i have done to it is a little cleaning and deoxit. Not even a bulb has burned out on this thing.
  #3
Old 08-27-2009, 12:38 PM
ToasterBin's Avatar
Toasterbin
Toshiba Receivers
Thanks Nick!
  #4
Old 08-27-2009, 12:42 PM
KingBubba's Avatar
KingBubba KingBubba is offline
"Too Much Stuff"
I have an SA-520 and other than peeling vinyl it is a very strong performer.
__________________
Sansui G6000,7070
Pioneer SX1250,SX1280
Kenwood KR-8010
Onkyo TX8500II
Pioneer CTF950,Akai GX-S80
DCM TF-600,TF-400 CX-17+ KL Quartets
  #5
Old 08-27-2009, 05:49 PM
tannyhoban's Avatar
tannyhoban tannyhoban is offline
tannyhoban
Toshiba
I have owned two Toshibas, the SA-7100 and a SC 335 Amp. Still have an SA 7100 and it is indeed built like a tank (50+ lbs.) with very solid sound and a good tuner.
The SC 335 gave me 10 years trouble free and I regret letting it go, it was a little freak of an amp.
I wouldn't hesitate to pick up more of the Toshiba gear from the late 70's, early 80's - it's good stuff and frequently flies under the radar.
__________________
"Wherever you go, there you are."
Audiokarma
  #6
Old 08-27-2009, 08:59 PM
hpsenicka's Avatar
hpsenicka hpsenicka is offline
Moderator
Moved thread from "Equipment Reviews".
Note: a request for information, is not a review.
  #7
Old 08-27-2009, 11:09 PM
superdog's Avatar
superdog superdog is offline
AK Member
I have a sa520 I believe in the garage.I know it works but haven't heard it in so long I couldn't give you an opinion on it.It did come up on a ugliest receiver thread here once.
__________________
Yamaha ~Sony~ARC~Luxman~Hafler~Pioneer
Kef~AR~EV~JBL~Bozak~CV~Vandersteen
  #8
Old 08-27-2009, 11:17 PM
rob29's Avatar
rob29 rob29 is offline
AK Member
I have a yoshiba sb-620 integrated and the 335 seperate set (sy-335, sc335, st-335) The integrated is rated at a modest 62W/ch but seems to put out much higher output and is built like an absolute tank. The 335 amp gave me troubles from the beggining but after a complete overhaul it sounds amazing but is only about 40ish W/ch. I find the sound extremely relaxed, especially the 335 set and I dont think I will be parting with either set any time soon.
  #9
Old 08-27-2009, 11:25 PM
mrbruce mrbruce is offline
AK Member
An SA-3500 here that I do not plan to part with. A very solid receiver, both tuner and amplifier sections.
  #10
Old 08-28-2009, 05:43 AM
Michael-Otto Michael-Otto is offline
AK Member
Here the specs from a TOSHIBA catalog 1977, only in german
Technische Daten HiFi-Stereo-Receiver SA 520
FM
Empfangsbereich:87,5-108 MHz
Antenneneingang: 75 Ohm, 300 Ohm
Eingangsempfindlichkeit: 0,6 µV (26 dB, 60 Ohm), 1,2 µV (26 dB, 240 Ohm)
Klirrfaktor: MONO 0,2%, STEREO 0,4%
Frequenzgang: 20-15.000 Hz
Fremdspannungsobstand:70 dB
Kanaltrennung: 40 dB
Gleichwellenselection:1,0 dB
AM-Unterdrückung: 55 dB
ZF-Unterdrückung: 100 dB
Spiegelfrequenzunterdrückung:80 dB
Trennschärfe:65 dB
Pilottonunterdrückung:60 dB
MW
Empfangsbereich: 525-1605 KHz
Empfindlichkeit: 15 µV
Fremdspannungsabstand: 50 dB
Spiegelfrequenzunterdrückung: 40 dB
ZF-lJnterdrückung: 70 dB
Verstärker
Sinus Ausgangsleistung: 2 x 37 Watt, 4 Ohm, 1000 Hz, 2 x 35 Watt, 4 Ohm, 20-20.000 Hz
beide Kanäle betrieben
Musik Ausgangsleistung: 2 x 47,5 Watt, 4 Ohm
Frequenzgang: 15-40.000 Hz + 0,5 -1 dB
Klirrfaktor: 0,4%
IntermodulationsVerzerrungen: 0,4%
Lautsprecherimpedanz: 4-16 Ohm
Kopfhörerimpedanz: 4-16 Ohm
Dämpfungsfaktor: 45 - bei 8 Ohm
Eingangsempfindlichkeit und Impedanz:
Phono mag: 2,5 mV, 47 KOhm
AUX: 150 mV 50 KOhm
Tonband: 150 mV 50 KOhm
Tonband DIN: 150 mV, 50 KOhm
Loudness: + 10 dB (100 Hz), + 5 dB (10 KHz)
Baß-Regelbereich: ± 10 dB (100 Hz)
Höhen-Regelbereich: ± 10 dB (10 KHz)
Allgemeines
Halbleiter: 6 FET's, 2 ICs, 42 Transistoren, 26 Dioden
Stromversorgung: 220 V, 50 Hz
Leistungsaufnahme:´310 Watt
Abmessungen: 530 x 158 x 435 mm
Gewicht: 18,5 kg
Michael-Otto
Audiokarma
  #11
Old 08-28-2009, 06:08 AM
dshoaf's Avatar
dshoaf dshoaf is offline
That high voltage buzz
Sold them back in the 70s. When my dealer took on the audio product line, the sales guys considered them a second-level product line to the Marantz, Pioneer, Sony stuff. When I pulled one apart for them to see inside, they changed their minds.
At the time, most Toshiba, Sanyo and other similar brands were associated with clock radios, and similar little devices that showed up in Dime Stores, discount/KMart, and drug stores.
For the dealer, Toshiba was agressively priced so that there was better margin in their products, which translated to higher profits. This was because Toshiba didn't advertise or get product reviews from the audio magazines. Today, this explains why there's less known in general about the products.
In fact, their gear was quite good, performed as good as the big-name gear and still does today - when you can find them. I doubt their sales volumes were anywhere near those of Sony, Pioneer, etc.
Cheers,
David
  #12
Old 08-28-2009, 08:55 AM
donberry donberry is offline
AK Member
I have a Toshiba SA-775. Mainly kept it because it is rather unusual looking. Does garage duty with a pair of HPM-100's, or rather, it does my outdoor duty as I open the garage door and crank it when I am outside(have to love the country).
Well built receiver. I prefer the sound of my Kenwood KR-7600 (same power), but the Toshiba sounds fine, Kenwood just a little warmer, which could be a good thing or a bad thing, depending on speakers and personal preference.
In the late 70's, was not nearly as popular as the other major names, but just because it was not as popular does not mean not as good.
Kenwood is known for some pretty decent tuners on their receivers - the Toshiba picks up stations better then the Kenwood.
Seems it does not have the clarity though, BUT, could very well be it just needs, no, I know it needs, re-capped.
Overall a very satisfactory receiver. Actually is my most used one at the moment. Must be tough as heck as it is in my un-cooled garage where it is easily over 100 degrees and cranked up for long periods of time - has yet to break a sweat.
Actually, more I think about it, more I want to bring it in and recap it and move it to a better climate......uh-oh, you just condemned my Kenwood to the 2nd garage...
__________________
ML SL3 - "While some people may prefer a speaker that demands less from them, these speakers are designed for those who demand nothing less than the best from their speakers." Stereophile Review 1997
  #13
Old 08-29-2009, 01:43 PM
KingBubba's Avatar
"Too Much Stuff"
I just looked at my Toshiba receiver yesterday and realized it is a 520, not a 620 as I had remembered. I used it for a long while in tandem with my Kenwood 8010 and it held its ground. It is a nice sounding receiver and I am glad I paid the $8 for it.
__________________
Sansui G6000,7070
Kenwood KR-8010
Onkyo TX8500II
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
