Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 09-11-2009, 06:56 AM
Soggy Soggy is offline
AK Member
Rectilinear 3 driver replacement
Has anyone out there replaced the tweeters or supertweeters in Rectilinear 3s?
I sometimes wonder (and I've seen posts from others) if replacing the Peerless cone tweeters with more modern soft dome tweeters would give a better sound or spatial soundstage.
The Rectilinear 5 seems similar to the Rectilinear 3 in many ways but with newer style drivers. One possibility that comes to mind would be to replace the Rec 3 tweeters with those used in the Rec 5 or in the Dahlquist DQ-10s.
Or simply with newer Philips soft dome tweeters.
Has anyone tried anything along these lines?
thanks,
Soggy
  #2
Old 09-11-2009, 08:47 AM
dnewma04's Avatar
dnewma04 dnewma04 is offline
The Healer
The old peerless cone tweeters were about as good as it got for the format with good extension and even pretty decent off axis response that gently rolled off, not nearly as beamy as some cones. If you like what you hear, I don't know that you'd be happy with the results if you swapped the tweeters out. If you are thinking you are missing some freq extension and don't mind tearing them up a bit, it never hurts to play around.
__________________
"Digital is a swiftly moving stream, purling sweetly. But analog is a cataract bounding cacophonically off boulders and precipices, smashing into logs, and spraying drops and puddles everywhere."
  #3
Old 09-15-2009, 04:49 AM
AK Member
I always assumed that the smaller Peerless tweeters in Rec IIIs are the supertweeters.
But I just read a posting in an epinions consumer site that described the larger tweeters as the supertweeters.
Anyone know which is which?
Thanks
  #4
Old 10-28-2011, 04:28 AM
Knight Hawk's Avatar
Knight Hawk Knight Hawk is offline
AK Member
Thanks
I've owned a pair of these venerable speakers since 1970. According to the official replacement driver list the smaller, i.e. 2 inch driver is the "super tweeter". See list here: http://sportsbil.com/stereo/rectilin...ivers-1976.pdf
I also ran across someone else asking whether replacing the tweeters with updated ones was a good idea. The general consensus was "no". The Rec III's are a very well engineered system, especially for that era. The drivers and crossover are accurately balanced, and attempting to "improve" performance with different drivers would most likely just end up unbalancing them.
The paper cone tweeters used in the Rec III (there are 2 x 2 in. and 2 x 2.5 in. in each cabinet.), are actually quite excellent. However, it seems that they tend to suddenly die over time, and the musical overtones would then tend to be less balanced. I lost a couple tweets on my pair of IIIs, but I'm no longer able to hear as well in the extended high frequencies, so I don't seem to notice it. Indeed, to my ears, these old boxes still sound remarkably accurate in the high end. Nevertheless, I've been looking around for replacement drivers. Can anyone help me?
  #5
Old 10-28-2011, 08:01 PM
stickman stickman is offline
AK Member
The Rec III's are known for being non-fatiguing for extended listening periods and the Peerless cone tweeters are the primary reason why. They lack the peaks and resonances (both in the audible and above audibility frequency ranges) found in most tweeters and especially dome tweeters of all types. If you wanted a little more zing on the very high end I would consider just adding some stand alone super tweeters on top like the venerable Foster/Fostex conical horn loaded units sold for years by Radio Shack, but you will need a potentiometer to adjust the relative volume level.
I owned some Rectilinear 5A's and the first generation Philips polycarbonate hard dome tweeters they used were painfully peaky! That is definitely NOT something to consider!
PS - Since many speaker builders used the Peerless cone tweeters back during the 1970's, used units appear quite frequently on Fleabay. To find them though you need to do a general search, such as for "Vintage Tweeters" and spot them by appearance. Just make sure you get units with the proper ohm rating. I have some Tandberg speaker Peerless cone tweets that are rated at 3.2 ohms!
Audiokarma
  #6
Old 10-28-2011, 08:15 PM
Soundminded Soundminded is offline
AK Member
I only heard Rectilinear III a few times and thought it was an excellent speaker. One of the magazines compared it to the Quad electrostatics and said it sounded the same except it had better bass. Rectilinear III was featured as the speakers in an article in one of the hobbyist electronics magazines, might have been Popular Electronics in "The Stereo System I Wish I Owned."
Rectilinear V was an altogether different animal. It was designed by Dick Shahanian and frankly I don't think it was a very good speaker system. It used a Phillips tweeter crossed over at some high frequency like 11 Khz. He thought that was very clever. I only heard it once at a trade show in NYC. It was being driven by a Dynaco Stereo 400 and the sound was badly distorted. I didn't like it. His clever idea of time alignment, all the rage in the mid 1970s when it was introduced was to tilt the speaker back 4 degrees. Big deal.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
