Hi there,
New to the area!!
I recently picked up an AU-919 that seemed to be in reasonable shape. Anyway having now cleaned it I started to go through the signal path and have discovered that the left channel appears to oscillate under certain conditions. I have traced it down to the "Flat amp". When the "Jump" switch is engaged the flat amp is bypassed and all seems well. The situation becomes a little worse when the tone controls are engaged - since these are wrapped around the flat amp so this seems logical.
I have taken the board out, cleaned it and resoldered all joints. There was a lot of gunk and crap on the board. It appears a little better on the oscilloscope but not 100%.
I was hoping somebody has run across this and has some pointers. Next steps may be replacing some of the caps and such.
Cheers in advance!!
Steve
New to the area!!
Cheers in advance!!
Steve
