Duffinator
Spin The Black Circle
I've posted a couple of other threads about the 4425's I purchased last summer and I'm finally getting to restoring them. My goal is to use AK member gonzomeeps restoration instructions and get them back to their former glory. The first thing I need to do is rotate the horn mounting plate on the donor cabinet.
The first question I have is has anyone ever removed one before without destroying the cabinet? Can it be done? The plate is mounted with six screws, 3M double sided mounting tape, and some glue. I used the old damaged cabinet as a test and as you can see from the photo it took part of the cabinet with it. Most likely it was damaged when it was dropped but I want to make sure before I start on the good cabinet. Both good cabinets I have are left sided and I need to rotate the plate so the speakers remain mirror imaged. My plan is to work a thin putty knife from the inside edge where the horn mounts and see if I can pry it up. If anyone has done this or has any suggestions or good ideas on how to remove the plate please let me know. Below are the first photos.
The first photo shows the damaged cabinet before removing the plate.
The second photo shows the damaged cabinet after removing the plate.
The third photo shows the good cabinet before removing the plate.
The last photo shows the speakers after refoaming the woofers and before the restoration started.
