Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #46
Old 11-01-2009, 09:01 AM
rtate rtate is offline
AK Member
Lance,
where did you source the white blocks that the pcb's are mounted on??
__________________
Marantz 2385, 2220B,2230,Leach superamp x 7,Parasound AVC2500u,Aria5r,Shiva 12" subs x 3, Bride of Zen preamp,denon dvd5910ci, dvd2900,Dahlquist DQ10
  #47
Old 11-02-2009, 10:00 AM
westend's Avatar
westend westend is offline
AK Subscriber
Quote:
Originally Posted by DENNYDOG View Post
Looking good Lance! Everyone should know that metalwork like this isn't as hard as it looks. A lot of the stuff can be done with basic tools most everyone has around their house. And those metal blades are the hot ticket aren't they?! We have a couple skillsaw style saws at work. Amazing that you can cut through 1/4" plate steel like butter. They will cut through 1/2" or thicker if your patient.
Yessiree, the Amana blade is a treat to use, Denny, and you're absolutely right about the ease of the metalwork. Anyone that has decent measuring tools, a drill, and is in any way practical, should be able to build a fairly nice chassis.
Quote:
Originally Posted by rtate View Post
Lance,
The standoff blocks are HDPE (high density polyethylene) that I had left over from making various slides and fences for woodworking tools. I followed Tal's lead on that and they worked out very well. The material is available at local woodworking stores like Rockler, Woodcraft, etc..
Update on the build: All is in place and wired (I did'nt have any light on the LED's and I may have to cjhange resistor value or might have the leads reversed. That segues into the initial startup process (regarding the "reversal" bit). I checked the AC values, DC values from the transformer, and the resistance of the trim pots and all looked good.
I hooked up the poor mans variac and stated to measure voltages. I had a value of .346v acoss R11 and R12 and, in hind sight, that should have let me know that something was amiss. But, since the value was lower than the operating value and I assumed it would not rise above .59, I let the amp idle with the bulb for an hour or so and then fired it up under full power. I was busy monitoring the rail voltages when I smelled that awful smell, yikes, R11 and R12 are HOT, HOT HOT. Hit the power switch and sat back for a moment. What could be the problem? Could I have mistakenly shorted something on the output side? Is something loose or a soldering mishap?
Here's what happened:The bourns trim pots are set so that the wiper is positioned to resist the current in the fully clockwise position. In my pea-brain I thought this was counter-clockwise. I powered the amp with full current enabled. I will replace the R11 and R12 resistors, turn down the trimpots and try for another go at setting the bias.I think I may have saved everything downstream in the amp circuits because I was able to power down quickly. The .047 3w resistors still measure in spec and the mosfets barely got the heatsinks warm. Hopefully, the Jfets are still OK. I do have thermistors attached to the cases and the current limiting is on the boards so I might have dodged a big bullet.
At least one Pass builder is able to share some drama and screwups. Attached are pics of the poorman's variac, the amp as it is built, and the smoked resistor.
  #48
Old 11-02-2009, 10:53 AM
AK Member
Lance,
Are the standoffs threaded into the HDPE or glued??
__________________
  #49
Old 11-02-2009, 11:53 AM
qboneus's Avatar
qboneus qboneus is offline
Senior Member
Lance,
I can't speak for Lance but 'I' threaded mine..
Looks awesome Lance!!!
cheers,
tal
__________________
Too much stuff to list, and i'm tired of it taking all that space under every one of my posts!
  #50
Old 11-02-2009, 12:07 PM
specialidiot's Avatar
specialidiot specialidiot is offline
a special kind of idiot..
Nice work Lance. I actually smoked one of my R11/R12 pairs too.
Regarding the stand0ffs, I understand the desire to mount the boards on something, and I actually communicated with some of the other builders on diyaudio.com about this. Most don't mount to a solid base, mostly because the board is so light that it's not needed. Many also contested that having the boards solidly mounted could cause trouble with added stress on the pads of the pcb. I argued that if you mount to the standoffs, then soldered it shouldn't matter.
But bottom line, my boards hang by the TO-220's from the heatsink. I run mine multiple hours per day, ever day for several months now without issues.
__________________
Up: TubeDAC-09 as pre, Pass F5 diy, Pro-Ject RM5-SE/Dyna 10x5,Sony XDR-F1HD, MacMini, Indignia
Down: HF-81, Foreplay III w/6SN7's, DIY SET 45, Cornwall II; C-2x, MX-2000, Diatone DS-77HRX; various sources
Projects: KLH 17, Yamaha CR-1020
, Pass F5 DIY
Audiokarma
  #51
Old 11-02-2009, 01:06 PM
Russellc's Avatar
Russellc Russellc is offline
AK Member
Many have done the Daniel's boards in a similar fashion. The mosfets are against the heat sink, with legs bent 90 degrees so they stick out. Board is lowered onto the legs and soldered in place, with board hovering over the heatsink, held in place by the pins and solder. Likely how I'll do mine, plus it doenst use any real estate up inside the case.
Russellc
__________________
AR The TurntableW/Scillia/Merrill Mods/Unitrac
AVA SuperpasIII,Counterpoint SA1000,
Mcintosh Mc225, HomebrewP-P 6550, JBL 6230,
Mitsubishi DA-A15DC, DIY Pass F-5 & B-1 Indignias,
Altec A7,Aria5,Microns,Econowave(JBL4647w/2235H)
MR 67, FM-3,Mitsubishi DA-F10, Rotel 971
  #52
Old 11-02-2009, 04:40 PM
westend's Avatar
AK Subscriber
Lance,
I press-fit and glued the nylon posts into the blocks. I used a two-part epoxy to glue them to the chassis bottom.
Jeff, that takes a little of the sting out of my "senior moment", knowing I'm not the only one that screws up .
Hanging the boards should work out OK. The legs on the mosfets are pretty sturdy. It sure makes for easier removal, if needed. I just am an old sailor, at heart, and tend to overbuild and secure everything, don't know what kind of weather is coming.
I still need some time to asess my stock of resistors and measure the ones on board that are all toasty. I might venture a restart.
  #53
Old 11-02-2009, 10:49 PM
westend's Avatar
AK Subscriber
Muhahaha...it lives!
Must have been a Halloween thing going on , all is now good. Voltages are fairly stable and DC offset is almost non-existent, .000-1 DCV.
I guess a Haiku is in order for NP: Simple and sweet amp
Silence hardly warms the soul
Waiting to enjoy
I'l let her run for awhile and keep an eye out for any drifting. It's been fully powered for about three hours and is barely warm, I could leave my arm or hand on there indefinitely. I think the all aluminum case is a good idea. I can see that the whole case is acting like a heatsink, the back, front, and bottom are all just slightly warm.
  #54
Old 11-02-2009, 10:51 PM
Well done Lance!
Enjoy the music....
__________________
, Pass F5 DIY
  #55
Old 11-02-2009, 11:25 PM
westend's Avatar
AK Subscriber
Well done Lance!
Enjoy the music....
Thanks, Jeff for leading the way on these F5 builds. I could not have done it without your thread and Tal's help. It is actually a pretty easy project, as Nelson put it, "So easy a Geico customer could do it". But your thread and Tal's were referenced many times.
I plan on hooking up the Yamaha C-2A and the Plant Hangers to see what this sweetheart can do.
On a side note, I was talking to an anodizer, a few days back, and he seemed to think he could run a few pieces for me for pretty cheap. I'm really getting used to the polished aluminum look and may keep everything but the faceplate and top in it's polished state. Maybe throw a coat of laquer or some such on the polished stuff and get a silverish-grey/black anodizing on the top and face. That might blend between the silver and black gear and approach the Kenwood Euro anodize that I really like.
Audiokarma
  #56
Old 11-02-2009, 11:49 PM
thefragger's Avatar
thefragger thefragger is online now
Certified Crazy.
Excellent!
That looks great! Now what about a face, Lance??
__________________
Quote:
Originally Posted by thefragger
I just don't get it, this amp was fine before I put it under the knife
Join the GTA / Toronto AKers Group!
  #57
Old 11-03-2009, 07:55 AM
Russellc's Avatar
AK Member
That's great westend, I cant wait to fire mine up. I'll remember to double check the pot settings before hand. I do have a variac, so that may ease the problem. Hook that beast up to some speaks!
Russellc
__________________
  #58
Old 11-03-2009, 02:58 PM
westend's Avatar
AK Subscriber
Quote:
Originally Posted by thefragger View Post
Excellent!
Thanks!
I've got some work to do on the faceplate. My current plan is machine an edge on face, finish process the six surfaces, see if I can get an "F5" graphic of some sort, and meet with the anodizer to see if he can apply a tint to meet my choices. I'll be firing up the router, this evening, to see what I can accomplish.
Quote:
Originally Posted by Russellc View Post
That's great westend, Icant wait to fire mine up. I'll remember to double check the pot settings before hand. I do have a variac, so that may ease the problem. Hook that beast up to some speaks!
Russellc
Hey Russel,
I used the "poor man's variac", the 100w bulb device. Unfortunately, it was the first time I used it so I didn't know how it would limit current. I did know that it would show if I had a short and since all was good and no shorts I proceeded to full power. Within a few seconds, I realized all was not good and I flipped the switch to save the components from damage.
I had measured the trimmers before installation (this is really the best way) but trying to measure the resistance value in circuit does not lead to accurate results. I was relying on past information so I turned the wiper fully counter-clockwise. That is wrong!The 5k Bourns pots are zero'd by turning clock-wise.
A variac, of course, is the best choice, and I have been looking for one for reasonable price. Heck, I have an Oscope that just arrived and haven't had time to put it through the paces. A man can't have enough tools is my motto .
I will, hopefully, have the F5 hooked up to listen, tonight. Will report back with results.
  #59
Old 11-03-2009, 03:07 PM
Russellc's Avatar
AK Member
Depends on which boards you are using!
Quote:
Originally Posted by westend View Post
Thanks!
Hey Russel,
As to the pots, there is a difference in the Cviller and Daniels boards. they connect different legs together a little differently than each other, resulting in OPPOSITE results. One results in minimum reading counter clockwise, the other clockwise. There is a very recent post on the F-5 thread over on DIY.
Russellc
__________________
  #60
Old 11-03-2009, 03:12 PM
Russellc's Avatar
AK Member
Russellc
Whoops, I see you have already been there and that advice may be in question, sounds like maybe they have it backwards? I have the daniels boards, so I need to find out....
Russellc
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
The Tube Store
Grant Fidelity
AudioClassics
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
TR Audio
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
Politicalchat.org
Yesterday's Audio
Zebra Cables
Radio X
MCM Electronics
Videokarma.org
Avanti Audio
esmokers.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
