dd123
My first post in the Pioneer section. A few months ago I came across an sx-1250 in great condition and was lucky enough to get it. Man, what a magnificent beast! The only glitch is that one channel fades out and in occasionally. markthefixer gave me a helpful nudge to post what I'm doing in order to get some help.
I took pictures hoping to help others (and so I can get things back together :yes
. One pic shows which front panel screws are for the switches and pots boards. Others show the boards themselves.
The follow up reply has a pic of the button boards and a top down view showing the honkin' big caps. Another pic shows the slots at the bottom of a switch where DeOxit can be sprayed as described in another post. Before finding that post I had carefully pried off the cover of one switch only to find it wasn't worth the effort because it didn't give any better access to the contacts.
There are also two pics showing how to remove the cover of a button. But for the inexperienced (like me) I think spraying DeOxit into the slits along the edges of the cover is a better idea. I kind of munged up the muting and multipath buttons when I put their covers back on.
They are a bit off mechanically now. One doesn’t stay in sometimes and the other pushes hard. I may have jammed their springs or something. Any ideas for a fix?
OK, so far I've done the DeOxit thing on the switches, buttons, and balance pot. I haven't done the sealed volume pot. I also haven't done the input selection buttons because that board wasn't going to come out easily. Instead, leaving that board in place I sprayed those buttons as far down the shaft as I could get, as described in another post. I will drill and spray the volume pot if that is warranted.
But I did some basic troubleshooting and got some interesting results that make me think it's probably not the volume pot. With the power on I found these repeatable ways to bring the faded channel back (until it fades out again):
1) Flip the Loudness switch on
2) Rap the top of the left rear honkin' big cap with my knuckle
3) Increase the volume (jiggling the shaft of the volume control did nothing)
4) Turn on a fluorescent light plugged in to the same outlet as the 1250!!
So, do I have to bite the bullet and replace the big caps - I don't see any signs of leaking. Or are there other things worth trying first? And where the heck would I get replacements for the big caps anyway?
