Congrats reneborg! Your at the doorstep of a ton of fun and I hope the DIY bug bites you.
I started pretty much where you are now and I suggest you try everything you suggested. Get in there and learn. ...
marc mc
Thanks marc mc! I think the bug has already bit me, as I've been fooling around a little bit with some electronics I've picked up for free or very cheap. ... as a matter of fact, I think there is some type of 'cross-contamination' because it was my quest for new to me vintage electronics that got me to buying speakers. I'm intending on learning basic skills on these, and I've already got a pair of Realsitic Optimus 5bs that are going to be my next speaker rebuild -- that is, unless I pick up something else before then
These speakers are actually part of a system I'm putting together for my 9 year old son.
... The speakers worked perfectly, all drivers were ok, just the cabinets were messed up. So I refinished the cabinets. It's a lot of fun, and I enjoyed every minute of it. It was much better than just sitting at the computer and reading, I actually got to work on something on my own time and just for me.
It's definitely worth fixing up an old set of speakers that have either seen the ravages of time, or the misuse of an owner. Plus, it gives them a little bit of a sentimental value.
These need to be refinished some too -- I have to figure that out as well. It has some chipped corners (I think it's a veneer over particle board), and I figure I'll either paint the whole thing or veneer it -- but I'd have to learn that part as well.
I definitely agree that it's worth fixing up old stuff -- I think it's fun, you learn, and sometimes save tons of $$$ while getting a better outcome. I've always been a DIYer, though my fixing up stuff has previously been cars, computers, and house stuff like plumbing, electrical, and carpentry.
My 2 cents: Econo-wave:
http://audiokarma.org/forums/showthread.php?p=1856214#post1856214
The thread lays out a standard high frequency compression driver and waveguide that can be used with lots of different woofers. Lots of easy paint-by-number, connect-the-dots instructions. Big bang for the buck, a tremendous learning experience and you wind up with a great sounding pair of speakers. I've converted different 4 pairs of vintage Altec cabinets to this format - and prior to that I had never done ONE.
Thanks Rosso!
I was hoping to do something with the great body of information/knowledge there, but, frankly, I have been overwhelmed. It's not that the technical info is too over my head -- I can learn -- it's just that I don't know where to begin for my purpose; that is, I've got a cabinet, and I'm trying to figure out what drivers and crossover to use. Specifically, I go to the
parts list and don't see where are the low-frequency drivers. Any guidance? I think what I need is for someone to point me to the place where I can figure out how to match components to the cabinet I have.
Maybe my knowledge is too basic to get this all, but I thought that I would pick a driver combo to work in the cubic volume of what my cabinet is and also need to match the drivers to a crossover. So the part I don't get is where do I figure out which woofer to go with, for example, this
driver or any other one I like.
I did a little more hunting around in these cabinets, and figured out that:
1) the current 'crossover' is super simple. I say this because it looks like the input to the speaker terminal goes full range to low frequency driver while the other branch goes to a cap and resistor(?) and then to the tweeter.
2) the wiring is like this:
Speaker Terminal --> branch one --> woofer + -- (doesn't this make this operate as a 'full-frequency' driver?)
Speaker Terminal --> branch two --> Electro-Cap 1.70uf +-10% 100v-F3074 386-1029
Electro-cap --> ?resistor? 428-1103 1ohm 10% 5W
Resistor --> Tweeter + --
So, based on the tiny bit I know, doesn't it seem like I should replace this crossover, and get a high and low frequency driver to match the new crossover?
Thank you all for your suggestions and time!
