xoaphexox
Supernatural Anesthetist
I am about half way done restoring an SG-9500 that I picked up two weeks ago along with two full racks of gear (here).
So far I have:
Stripped and cleaned the chassis
Cleaned the face plate with Mother's Chrome Polish
Replaced the power supply caps with Panasonic FC
Replaced the regulators with new 2SD313/2SB507
Replaced the other transistors with low noise Zetex 694B and 795A
Replaced the lytic caps in the EQ with Elna Silmic II
Replaced the mylar caps with Polypropylene caps (Panasonic ECQ-P(Z) and WIMA)
Replaced all fuses with new 500mA LittleFuse
Reflowed all the solder joints.
Right now I have one channel done as you can see in the pics - I am thinking about A/Bing the unit to see if I can tell a pronounced difference.
I know this is overkill... but once I get started I have a hard time pulling the plug!
Also torn down to be restored next is a TX-9500II, SPEC-1, SPEC-4, SG-303, and RG-2. I restored the DT-500 this weekend. Then they will all get shoved back in to a rack!
I wish I could find modern opamp replacements - I had great results a few months ago replacing all the opamps in a Sansui SE-7 with Burr Brown OPA2134's...
So far I have:
