The recent debate over the suitability of using the Technics overhang gauge on the AT-PL120 tonearm got me thinking, so I dug out my Stevens protractor from Vinyl Engine and the Shure protractor from my M97xE cartridge to see what, if anything, they could do for my PL120. The results were disappointing. It was impossible to satisfy these protractors keeping the cartridge straight in the head shell no matter where they were placed in the slots, which meant that with a straight positioned cartridge the stylus would likely never find a null point on the record. I had to turn the cartridge inward to get things to line up with the protractors. The resultant sound with both protractors was muddy and missing most of the highs the Technics gauge setup provided. I downloaded and examined both the PL120 and LP120-USB pictures from the audio-technica web site. The cartridges in both pictures looked to be straight in their head shells with their front panels about even with the front edge of the head shells, and these cartridges come aligned from the factory ready to plug and play (it says so in the manual). It became obvious that I needed to go to audio-technica for an explanation so I sent an e-mail to tech support asking what procedure I needed to follow to put a new cartridge in a head shell for my PL120. On my second try I got a response which included a .pdf file of the free downloadable alignment protractor at EnjoyTheMusic.com.
http://www.enjoythemusic.com/freestuff.htm
This file prints out a protractor with null points at 70mm and 126.5 mm (my measurements), a bit farther out than the null points of my other two protractors. Again, with the cartridge straight in the head shell I could not satisfy the protractor. The setup I ended up with has the cartridge all the way back in the head shell and turned inward, but because the null points are farther out, the turn-in angle is not as extreme as with the other protractors. The sound clarity and high frequencies are there, it seems to image well across the record, and the setup provides two null points. What I have auditioned so far sounds "right". The setup looks nothing like audio-technica's pictures, but I plan to let things parked exactly where they are for a while and see what develops.
