Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Marantz Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-11-2009, 05:15 PM
wd409 wd409 is offline
AK Member
Marantz SR840 - troubleshooting assist needed
Please forgive my double post, I forgot there was a specifically marantz section on here and do not know how to delete the one from vintage audio.
Maybe a mod can delete that one for me?
This unit had a broken power switch which I went ahead and replaced with a confirmed working one, but it still wont gimme my sweet marantz sound
when I plug it in it lights up like you see in the picture, its unresponsive though to any button mashing exercise I go through. It makes me think its been hit by lightning but i see no burn marks or smell anything burned, so I need some help here.
unless there is some special way to turn this thing on that I dont know about, im guessing it has a short somewhere.
thanks in advance.
  #2
Old 12-11-2009, 05:33 PM
dspear99ca's Avatar
dspear99ca dspear99ca is offline
AK Member
Fried power switch + scrambled logic IC's = maybe you're right about lightning...
Check the secondary regulated power supply voltages that feed the boards with IC's... the FM MPX, the input selector IC that takes input from the front-panel microswitches, the preamp and phono section. If you're lucky there's a voltage regulator that's bad and that's all it is.... it's possible a single 7805 or 7812 feeds all of the logic in the beast.
  #3
Old 12-11-2009, 05:47 PM
AK Member
power switch wasnt fried, just broken. physically broken.
its one of those little push button deals to take it out of standby and it was damaged.
anyway, im gonna start checking things in a bit. I keep getting interrupted by the phone ringing, not that that is a bad thing, means someone wants to give me money.
  #4
Old 12-12-2009, 11:44 AM
AK Member
does anyone have a tech sheet for this beasty?
or, can tell me what the voltages of each wire coming out of the transformer should read at?
I havnt started testing on it yet but I dont remember seeing the board marked yesterday with whats what.
  #5
Old 12-12-2009, 07:59 PM
macman007's Avatar
macman007 macman007 is offline
Mcintosh..Made In USA
I'd start with a good cleaning inside and out. Looks like it's seen some moisture in it's past.
Then start cleaning all switches, buttons and ribbon cable connectors with deoxit. If it has a set of fins for manual dial tuning just blow it out, don't use cleaners just a soft brush and a little air pressure. I didn't notice if it had a manual tuning knob in your picture.
A clean unit with good connections and clean switches and controls is much easier to diagnose than one in this units current state of cleanliness and corrosion.
Might be as simple as a poor connection at one of those connector cables inside. Other will chime in here also. Look for a schematic online, Google can be helpful.
A lot of schematics are available online for free if you look hard enough. We may have one in AK documents.
May also be a logic issue if there was a voltage spike in it's history.
Good Luck, it looks like it's going to be a fun project! In the end it'll be worth it when your surfing the airwaves!
Phil
Audiokarma
  #6
Old 04-29-2013, 03:52 PM
The1thinker's Avatar
The1thinker The1thinker is offline
AK Member
I have the SR 940. Did u try to pushing the FM button. That is how you would regularly turn it on.
  #7
Old 04-29-2013, 04:08 PM
bktheking's Avatar
bktheking bktheking is offline
Gitter Done!
You're answering a 4 yr old post.
__________________
Citation Receiver, Sansui AU20000,TU9900,Marantz 8B,2500,18,150,1060,Pioneer sx-737/sx1280,heathkit sp2, KWka6000,kt7000,kc6060, Yamaha B2,C2,T2,C4,Fisher 500C,hk aa111, Puresonic 410-C, Tannoy Arden's, B&W DM2's,Klipsch Quartets,Technics SL110A,Empire 698
  #8
Old 06-23-2013, 01:27 AM
vfd fan's Avatar
vfd fan vfd fan is offline
AK Member
Question
i have qestion abaut am stereo module connector on tuner board
were is exactly located
__________________
Output. "Sound multiplex adapter" will enable sound multiplex receiver by connecting the external adapter.NV-6000
  #9
Old 11-27-2013, 08:29 PM
PhilA's Avatar
PhilA PhilA is offline
AK Member
I know it's a way old, dead thread, but I got the same result on mine when I put the ribbon cable into JP530 backwards. Stripe goes to pin 6 not pin 1, unlike all the other ribbons on the boards.
Just in case someone else makes the same mistake, because this thread shows up in Google.
Hope it helps someone
--Phil
  #10
Old 01-23-2015, 11:14 PM
vfd fan's Avatar
AK Member
Question
thanks in advance.
hi-i am search am stereeo module-can your help me
__________________
Audiokarma
  #11
Old 08-20-2015, 12:39 PM
ivantowerz's Avatar
ivantowerz ivantowerz is offline
AK Member
marantz sr840 found recently
I recently got this receiver from a hope chest second hand store for 5 dollhairs. Left side cuts out at low volume and balance fader is scratchy. There are no pots to clean so what do I look for to clean. Also, how do I remove the faceplate without breaking the timer switch dial?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Audio by Van Alstine
Capacitor World
AudioFriends
Meistertech Solutions
Vintage Home Audio
Okki Nokki
Analog Engineering Associates
Wargos Electronics
Organ Donor Parts
Hudson Valley Hi Fi
Sound Stage Direct
Take Five Audio
Parts Connexion
Howard Products
Simply Speakers
Audience AV
FM DX Antenna
AudioClassics
The Tube Store
Audio Doctor
RSL Speakers
Many Moons Audio
DeWick Repairs
BOI Audio Works
Yesterday's Audio
MCM Electronics
Amplifiedparts
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
