zeppoleon
Hello!
I recently just purchased a Pioneer SA-9100 off ebay. I have them hooked up to a pair of B&W DM602 S2 speakers (120W max, 8ohm). I have to say, the amp sounds amazing! Very clear and warm.
But after a few hours or so of listening to music, the pops and cracks started to appear. At first it was very subtle. My right speaker would make a small pop noise, and I wouldn't notice it was the speaker. But soon, the whole right speaker would crackle and pop audibly, causing the protection light to go on. When this happens I switch it off immediately. I re-re-checked all the connections, and everything looks fine. (FYI: I am using the A+B speaker settings. I have the left terminals on the A and B outputs going to the left speaker for bi-wiring, and vice versa for the right. I'm not sure if this is okay to do.) Anyway, I did something and it worked for another 3 hours until it all of a sudden crackled and pop'd and shut off. I wanted to make sure it wasn't my speakers, so I plugged in my headphones, and soon enough my headphones started to crackle and pop randomly. It's not exactly static, the music can be very clear up until this point.
Although the problem is mostly affecting the right speaker, the left speaker sometimes also crackles at the same time as the left one.
It seems the problem is getting worse, as when I turn on the amp today, the speaker sometimes immediately starts to crackle and make popping noises. The very sound makes me cringe. I switch it on and off again, and it stabilizes itself sometimes for a few minutes. It's just very fickle.
I have been lurking around, and have found threads that are related to my problem, but I want to get a personal opinion from you guys. I'm not very skilled at the electrician standpoint, but I'm sure I could do a few things my self to fix up this wonderful amplifier.
Help is much appreciated, thanks!
