131east23
...near Frank's Pizza!
A Garrard 401 versus a Garrard Lab 80? You might say there is no comparison, the 401 is superior. And in many ways it is. But it's not that superior to the Lab 80. Both were designed by Eric Marshall, The Lab 80 in '64 and the 401 in '65. They both have 6 pound platters that are rim driven by the same means, an idler wheel. The 401 has a shaded pole motor and an eddy brake that allows the user to adjust the speed, thus making the 401 a true transcription turntable. The 401 has three available speeds, 33 and 1/3, 45, and 78. The Lab 80 has a 4 pole synchronous motor that locks into the mains frequency, no speed adjustment and just two speeds: 33 and 1/3 and 45. If you read the reviews in "Gramophone" (the Lab 80 in '64 and the 401 in '65) you'll see that neither turntable exhibited any rumble and the wow and flutter was negligible, below specs. Now if you consider the going price for a 401, anywhere from $650.00 and up, to a Lab 80 which I paid $47.00 for you might start seeing that the Lab 80 and some similar older Garrards from the 50's and 60's might be worth some effort.
What made me buy this particular model after doing research on idler drive turntables was this: first, I really can't afford at this very moment a 301 or even a 401 that would require a custom plinth and the kind of tone arm/cart that I think would do it justice. And in that sentence alone I have already shown some bias in favor of the traditional audiophile set-up, which I am after. But, the fact that the lab 80 (at least the early Mark I's) are truly manual in the manual mode means that all of those gears and levers under the table don't operate at all when I'm spinning vinyl. There is no load on the platter or the motor other than the weight of the tone arm. It is a very nice MANUAL table. It's cons are that you pretty much have to use the tone arm that comes with the table, but after experimenting with tracking force it'll do anything you want. If you are on a budget, that tone arm with a good quality audiophile cartridge will surprise you! So yes there are limitations, but for $47.00 I find I can overlook those things for now.
I guess what I'm getting at is this: as the prices for idler drive turntables increase you might find a real gem for little money in some of Garrards lesser known, or much maligned "Automatic" turntables from the 50's and 60's. Some of us might get to a point where we are modifying these tables to suit our own purposes simply because they have terrific idler drives and heavy platters and over time have shown some dependability. I think the Garrard 4HF is another model that has some potential.
Any thoughts...
Any thoughts...
