jgordon
Often times I run across some white crap (seems almost like splattered paint) on the playing surface of my "vinyls." Not sure why it's consistently white, except maybe I just don't see the darker stuff. Anyway.
I've tried a number of things to help get it off, including x-acto knives and fingernails. But the best thing I've found is the red plastic wand of a compressed air can (or a WD-40 can). It's a soft yet firm plastic, and the small diameter of the shape allows you to "ride" the grooves and gently push at whatever's stuck to the record. I've gotten a number of particles off the playing surface with no damage to the grooves themselves this way.
Below is a pic. Basically you can control the amount of force being exerted on the crap with the angle of the tube and with your finger pressure. Gently nudge at the crap - you can feel the tip of the wand catching it, and push forward. It'll typically break away from the disc with a little prodding. And then you can blow it off the record, rather than drag it with a brush or the vacuum wand.
Hope this helps.
Hope this helps.
