Fisher RS-100 RS-200 RS-1000 RS-2000 Series Library Reference Thread
cbottorff
Member
There are Manufacturers' Forums here at AK for Grant Fidelity, Infinity Loudspeakers, Kenwood, Marantz, Linn Audio, McIntosh, Pioneer and Sansui, but not Fisher. Perhaps it is time that a Fisher group is added for the "Fisher Fanatics" as well. Let this thread be your motivation.
While I believe I do have some answers (and perhaps even a lot of answers) for my fellow Fisher fanatics, I have some (many?) questions as well, and hence my personal motivation for this thread.
When messaging me personally, please use the AK e-mail message feature rather than the AK internal messaging system as the AK internal messaging system is rather limited in both in message size and the total number of messages. At times I may not check my messages on a timely or even regular basis. Messaging me by e-mail alleviates any and AK internal message limitations. This way your message won't get a dreaded "message box full" send error.
Due to the highly technical nature of the information I am presenting subsequently herein, spell checkers and grammar checkers choke generating lots of false positive errors. Therefore, each receiver "spec page" (if you will) may have some errors including spelling and/or grammar in addition to whatever possible technical errors.
In any event, let us begin...
Fisher RS-1015
Fisher Receiver RS-1015
POWER AMPLIFIER SECTION
Continuous RMS sine wave power per
channel within stated bandwidth at no ............ 15W
more than stated distortion and with
an 8 ohm load.
Power Bandwidth .................................. 20Hz/20Khz
Total Harmonic Distortion ........................ 0.8%
PREAMPLIFIER SECTION
Input Sensitivity and Impedance
At rated output, 8-ohms at 1Khz
Phono ......................................... 2mV/50k ohm
Phono (max input capability) .................. 100mV
Auxiliary ..................................... 150mV / 100k ohm
Tape Monitor (1 and 2) ........................ 150mV / 100k ohm
Hum & Noise (below rated output)
Phono.......................................... 60dB
Auxiliary ..................................... 70dB
Tape Monitor .................................. 70dB
Frequency Response
Phono (RIAA EQUALIZED +/-2 dB) ................ 30Hz - 15kHz
Auxiliary Input +/-2 dB ....................... 20Hz - 20kHz
Tape Monitor Input +/-2 dB .................... 20Hz - 20kHz
Bass Control Range (at 100hz) .................... +/- 10dB
Treble Control Range (at 10khz) .................. +/- 10dB
Loudness Contour (at 30 dB volume attenuation) ... +8dB at 100Hz
... +4dB at 10kHz
High Filter ...................................... -6dB (4.5kHz)
Separation (stereo) @ 1kHz ....................... 40dB
FM TUNER SECTION
Usable Sensitivity Mono .......................... 2uV/11.2dBf
Stereo ........................ 4.8uV/18.9dBf
50 dB QUieting Sensitivity Mono .................. 2.8uV/14.2dBf
Stereo ................ 38uV/36.8dBf
Capture Ratio .................................... 1.2dB
Alt Channel Selectivity .......................... 65dB
Image Response Rejection ......................... 56dB
Spurious Response Rejection ...................... 85dB
AM Rejection ..................................... 55dB
Signal-to-Noise Ratio (MOno & Stereo) ............ 68/66dB
Total Harm. Distortion (Mono & Stereo) 1 kHz ..... 0.3/0.4%
50 dB Quieting Sensitivity THD 1kHz Mono ......... 0.4%
Stereo ....... 0.5%
Stereo Separation (1kHz/10kHz) ................... 40dB/30dB
Sub-Carrier Suppression (19/38kHz) ............... 60/70dB
AM TUNER SECTION
Sensitivity ...................................... 300uV/m
Selectivity ...................................... 40dB
Signal-to-Noise Ratio ............................ 55dB
Image Frequency Rejection ........................ 50dB
IF Rejection ..................................... 45dB
GENERAL SECTION
Power Requirements (50/60Hz) ..................... 120V AC +/- 10%
Power Consumption ................................ 160W/180VA
AC Outlets ....................................... 2
Dimensions H x W x D (Inches) .................... 6-1/16" x 19-1/8" x 13-1/8"
Weight (Lbs.) .................................... 21.6
It all started about three years ago when my twin brother acquired a Fisher RS-2015 stereo receiver that was blown in one channel for 100 barter bux. We weren't bothered very much by the "blown" problem because for us, "blown" is something we just fix, or better yet, tinker with, re-engineer and make better.
We didn't know the specs or anything about the RS-2015 at the time, so we consulted the Internet. And, the both of us, being very electronically inclined, were very pleased with what we found.
Fisher RS-1020
Fisher Receiver RS-1020
channel within stated bandwidth at no ............ 20W
an 8 ohm load.
Total Harmonic Distortion ........................ 0.5%
Frequency Response
... +4dB at 10kHz
FM TUNER SECTION
50 dB Quieting Sensitivity Mono .................. 2.8uV/14.2dBf
Signal-to-Noise Ratio (Mono & Stereo) ............ 68/66dB
Stereo ....... 0.5%
AM TUNER SECTION
GENERAL SECTION
Power Consumption ................................ 210W/240VA
Weight (Lbs.) .................................... 23
These aforesaid Internet searches also landed several links leading here to AK. This is how I found AK. One of the most common search engine hits Internet wide is generated by the "Amended list of 150+ wpc receivers!" sticky which has been copied by other individuals to many other Internet audio sites as well.
My brother and I have both serviced and repaired many different makes and models of receivers over the years including Akai, Denon, Harman Kardon, JVC, Marantz, NAD, Onkyo, Phillips, Pioneer (yes, including the SX-1980), Sansui, Yamaha as well as the more common Sears LXI, JC Penney MCS, and Realistic types (to say nothing of the 80s "black plague" that persists until now and all the black plague's progenitor(s) and/or spawn the likes of Emerson, KMC, Panasonic, Randix, Sharp, Soundesign, Yorx and all of that mess...)
Fisher RS-1022
Fisher Receiver RS-1022
channel within stated bandwidth at no ............ 22W
an 8 ohm load.
Phono (max input capability) .................. 110mV
Tape Monitor .................................. 150mV / 100k ohm
Phono.......................................... 75dB
Auxiliary, Tape Play .......................... 90dB
Tone Control
Bass (100hz) .................................. +/- 10dB
Treble (10khz) ................................ +/- 10dB
High Filter ................................... -6dB/5kHz
Loudness Contour (100Hz/10kHz) ................ 8dB/4dB
FM TUNER SECTION
Usable Sensitivity Mono .......................... 1.9uV/10.8dBf
Stereo ........................ 4.6uV/18.5dBf
Distortion Mono/Stereo (at 65 dBf) 100Hz .......... 0.15%/0.2%
1Kz .......... 0.15%/0.2%
6Kz .......... 0.2%/0.4%
Capture Ratio .................................... 1.0dB
Alt. Channel Selectivity ......................... 68dB
Image Response Ratio ............................. 56dB
Spurious Response Ratio .......................... 85dB
AM Suppression Ratio ............................. 58dB
Sub-Carrier Product Ratio (19/38kHz) ............. 60/70dB
AM TUNER SECTION
Selectivity (+/- 10kHz) .......................... 40dB
Image Response Ratio ............................. 50dB
IF Response Ratio ................................ 45dB
GENERAL SECTION
Power Consumption ................................ 300W/340VA
Dimensions H x W x D inches .................... 5-5/16 x 17-1/4 x 10-5/8
Weight lbs. ...................... 17
Ironic that Fisher has "ruled the decades" and has done extremely well during the black plague era (at least it looks to me that way) if you can call it that. (Heretic! He has spoken the forbidden words! Stone him! &c&c) Years ago: "(So, like,) my reference standard speaker to which I compare other speakers is the Vandersteen 2C." Which is true. Not bad for me during my adolescent days being 17 years old at the time in 1984 eh?
"Oh really?" "Yeah, and I kept borrowing a friend's set of Panasonic Thrusters also. I liked the Thrusters as well. (Yes, I have read the Thruster threads here on AK, these threads are hilarious to read.) ("What???!!! He has spoken more of the forbidden words! He must be put to death at once! &c&c) Uh... Where was I? Fishers. Oh yeah...
Fisher RS-1030
Fisher Receiver RS-1030
an 8 ohm load.
Frequency Response
... +4dB at 10kHz
POWER SECTION INPUT .............................. 150mV/50k ohms
FM TUNER SECTION
Stereo ....... 0.5%
AM TUNER SECTION
GENERAL SECTION
Weight (Lbs.) .................................... 24.3
ADDITIONAL FEATURE(S)
Pre Out / Main In RCA power amplifier connections
For some miraculous reason, neither of us, my brother nor I have ever seen or come across a Fisher model 1000 or 2000 series receiver over the decades, until just very recently. As common and popular as the Fisher 1000 and 2000 series are, I just don't know how this happened to us. So, for us "we learned something new."
Fisher RS-1035
Fisher Receiver RS-1035
channel within stated bandwidth at no .............. 35W x 2
an 8 ohm load.
Power Bandwidth .................................... 20Hz/20Khz
Total Harmonic Distortion .......................... 0.2%
Phono ........................................... 2mV/50k ohm
Phono (max input capability) .................... 110mV
Auxiliary ....................................... 150mV / 100k ohm
Tape Monitor .................................... 150mV / 100k ohm
Phono............................................ 75dB
Auxiliary ....................................... 90dB
Tape Monitor .................................... 90dB
Frequency Response
Phono (RIAA EQUALIZED +/-1 dB) .................. 30Hz - 15kHz
Auxiliary Input +/-1 dB ......................... 20Hz - 20kHz
Tape Monitor Input +/-1 dB ...................... 20Hz - 20kHz
Bass Control Range (at 100hz) ...................... +/- 10dB
Treble Control Range (at 10khz) .................... +/- 10dB
Loudness Contour (at 30 dB volume attenuation) ..... +8dB at 100Hz
..... +4dB at 10kHz
High Filter ........................................ -6dB (5kHz)
Separation (stereo) at 1kHz ......................... 40dB
FM TUNER SECTION
Usable Sensitivity Mono ............................ 1.9uV/10.8dBf
Stereo ......................... 4.6uV/18.5dBf
50 dB Quieting Sensitivity Mono .................... 2.8uV/14.2dBf
Stereo .................. 38uV/36.8dBf
Capture Ratio ...................................... 1.0dB
Alt Channel Selectivity (+/- 400kHz) ............... 68dB
Image Response Ratio ............................... 56dB
Spurious Response Ratio ............................ 85dB
AM Suppression ..................................... 55dB
Signal-to-Noise Ratio (Mono & Stereo) .............. 70/66dB
Total Harm. Distortion (Mono & Stereo) at 65 dBf ... 0.3/0.4%
T.H.D. at 50 dB Quieting Sensitivity Mono .......... 0.4%
Stereo ........ 0.5%
Stereo Separation (1kHz/10kHz) ..................... 40dB/30dB
Sub-Carrier Suppression (19/38kHz) ................. 60/70dB
AM TUNER SECTION
Sensitivity ........................................ 300uV/m
Selectivity ........................................ 40dB
Signal-to-Noise Ratio .............................. 55dB
Image Response Ratio ............................... 50dB
IF Response Ratio .................................. 45dB
GENERAL SECTION
Power Requirements (50/60Hz) ....................... 120V AC +/- 10%
Power Consumption .................................. 190W/228VA
AC Outlets ......................................... 2
Dimensions H x W x D (Inches) ...................... 6-1/16" x 19-1/8" x 13-1/8"
Weight (Lbs.) ...................................... 22.9
Over time I conducted further Internet research concerning the repair of the blown RS-2015, looking for the information, the service manual and original replacement parts. I've came across a lot of Fisher stereo information in general and as a result, I've collected a ton of this Fisher information, a lot of which I have saved and some of which I have compiled for use here including pictures of every single Fisher 100 200 1000 and 2000 series receiver I can find. The "stack" of Fisher receiver pictures gets larger every day. The Fisher receiver picture collection is currently 339 pictures totaling 62 megabytes.
Along the way I've also come across some apparently very "rabid" (in a good way of course) Fisher Fanatics over in Germany at a site similar to AK who really love Fishers with a great passion "RS-1080 Uber! &c&c". The site is all German so I can't read much of it but you can really see these people's Fisher excitement very clearly.
Fisher RS-1040
Fisher Receiver RS-1040
channel within stated bandwidth at no ............ 45W
an 8 ohm load.
Total Harmonic Distortion ........................ 0.15%
Phono (1 and 2) ............................... 2mV/50k ohm
Phono (max input capability) .................. 180mV
Phono.......................................... 65dB
Auxiliary ..................................... 75dB
Tape Monitor .................................. 75dB
Frequency Response
Phono (RIAA EQUALIZED +/- 2dB) ................ 30Hz - 15kHz
Auxiliary Input +/- 2dB ....................... 20Hz - 20kHz
Tape Monitor Input +/- 2dB .................... 20Hz - 20kHz
... +4dB at 10kHz
High Filter ...................................... -6dB (5kHz)
Low Filter ....................................... -6dB (60Hz)
POWER SECTION INPUT .............................. 150mV/100k ohm
FM TUNER SECTION
Usable Sensitivity Mono .......................... 1.8uV/10.3dBf
Stereo ........................ 4.3uV/17.9dBf
50 dB Quieting Sensitivity Mono .................. 2.5uV/13.2dBf
Stereo ................ 34uV/35.9dBf
Capture Ratio .................................... 0.8dB
Alt Channel Selectivity .......................... 70dB
Image Response Rejection ......................... 80dB
Spurious Response Rejection ...................... 100dB
AM Rejection ..................................... 65dB
Signal-to-Noise Ratio (MOno & Stereo) ............ 70/67dB
Total Harm. Distortion (Mono & Stereo) 1 kHz ..... 0.15/0.25%
50 dB Quieting Sensitivity THD 1kHz Mono ......... 0.3%
Stereo ....... 0.4%
AM TUNER SECTION
Selectivity ...................................... 43dB
IF Rejection ..................................... 70dB
GENERAL SECTION
Power Consumption ................................ 420W/470VA
Dimensions H x W x D (Inches) .................... 6-13/16" x 20-3/4" x 14-1/4"
Weight (Lbs.) .................................... 31.1
At first I only sought to acquire the service manuals for the models RS-1080 and RS-2015. As time went by, and as I've studied all the other Fisher models in the 1000 and 2000 series, I decided to acquire the service manuals for the models RS-1056, RS-1058, RS-2007 and RS-2010. Partially because I've seen a lot of other people here on AK and elsewhere on similar Internet audio sites are looking for these rare and hard to find Fisher service manuals.
Further time went by, and I found additional Fisher service manuals the were "just too cheap to pass up" and so the collection has continued to grow even beyond my original revised expanded collection.
Fisher RS-1050
Fisher Receiver RS-1050
channel within stated bandwidth at no ............ 60W
an 8 ohm load.
Frequency Response
Mid Range (at 1.5khz) ............................ +/- 10dB
... +4dB at 10kHz
FM TUNER SECTION
Signal-to-Noise Ratio (Mono & Stereo) ............ 70/67dB
Stereo ....... 0.4%
AM TUNER SECTION
GENERAL SECTION
Power Consumption ................................ 550W/620VA
Weight (Lbs.) .................................... 33.1
Further time went by, and I continued to notice even more individuals here on AK and other similar audio sites are searching for information on most Fisher RS-1000 and RS-2000 series receivers and yet there is pretty much a "dearth" of good solid information on these Fisher receivers of any kind other than a few Fisher fanatics here on AK such as myself. Yet for some reason, the information has never been fully or even partially published electronically in any form or forumn that I know of. This thread should rectify this problem in full.
Fisher RS-1052
Fisher Receiver RS-1052
channel within stated bandwidth at no ............ 52W x 2
an 8 ohm load.
Total Harmonic Distortion ........................ 0.2%
Auxiliary ..................................... 90dB
Tape Monitor .................................. 90dB
Frequency Response
... +4dB at 10kHz
FM TUNER SECTION
Alt Channel Selectivity .......................... 68dB
Image Response Rejection ......................... 85dB
AM Suppression ................................... 58dB
Signal-to-Noise Ratio (Mono & Stereo) ............ 70/66dB
Total Harm. Distortion (Mono & Stereo) 1 kHz ..... 0.15/0.20%
Stereo ....... 0.5%
AM TUNER SECTION
GENERAL SECTION
Power Consumption ................................ 230W/286VA
Weight (Lbs.) .................................... 23.8
As of this writing, I have acquired or will shortly acquire (currently in transit or are now awaiting me at the Post Office) the following original (not photocopies) Fisher service manuals for Fisher receiver models in the 1977 to 1981 model years:
1000 Series
Fisher RS-1015
Fisher RS-1020
Fisher RS-1022
Fisher RS-1030
Fisher RS-1040
Fisher RS-1050
Fisher RS-1052
Fisher RS-1056
Fisher RS-1058
Fisher RS-1060
Fisher RS-1080
2000 Series
Fisher RS-2002
Fisher RS-2003
Fisher RS-2004
Fisher RS-2004A (not as yet but soon I hope, some models are extremely hard to find)
Fisher RS-2007
Fisher RS-2010
Fisher RS-2015
100 Series
Fisher RS-140
200 Series
Fisher RS-225
Fisher RS-240
Fisher RS-245
Fisher RS-250
Fisher RS-255
Fisher RS-270
Fisher RS-280
Fisher RS-1056
Fisher Receiver RS-1056
channel within stated bandwidth at no ............ 68W x 2
an 8 ohm load.
Total Harmonic Distortion ........................ 0.1%
Phono (1 and 2) ............................... 76dB
Frequency Response
... +4dB at 10kHz
FM TUNER SECTION
Usable Sensitivity Mono .......................... 1.7uV/9.8dBf
Alt Channel Selectivity +400kHz ................ 75dB
Signal-to-Noise Ratio (Mono & Stereo) ............ 75/70dB
Total Harm. Distortion (Mono & Stereo) 6kHz ...... 0.15/0.25%
50 dB Quieting Sensitivity THD Mono .............. 0.3%
Stereo ............ 0.4%
Stereo Separation (1kHz/10kHz) ................... 45dB/36dB
AM TUNER SECTION
Image Frequency Rejection ........................ 56dB
GENERAL SECTION
Power Consumption ................................ 400W/498VA
Weight (Lbs.) .................................... 31.3
I haven't as yet acquired but may yet acquire the Fisher RS-36, RS-90, RS-110, RS-120 and RS-220 service manuals to complete the 1980 - 1981 series product line for sake of completeness and/or demand. The RS-110 and a pair of RS-225s are currently available on that "big auction site" e-B-a-y as I'm writing this as well as several RS-1000 and RS-2000 models from biggest to smallest in both 1000 and 2000 series.
What caused me to take the final plunge and acquire every single service manual with the ultimate goal of digitizing and publishing all for free are the facts that:
1) Fisher service manuals are of the best quality printing, both the quality of paper, and in the image quality. This cannot be said for the service manuals of other manufacturers, particularly service manuals I have seen from Marantz and especially Pioneer; and,
Fisher RS-1056
channel within stated bandwidth at no ............ 90W x 2
an 8 ohm load.
Frequency Response
... +4dB at 10kHz
FM TUNER SECTION
AM TUNER SECTION
GENERAL SECTION
Power Consumption ................................ 500W/612VA
Weight (Lbs.) .................................... 32.4
