Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-11-2010, 12:00 PM
Phototone's Avatar
Phototone Phototone is offline
AK Member
Yamaha MC-9 cartridge, any opinions?
In my stash of phono carts I found a Yamaha MC-9 cart. I have never mounted it (it is used), and my current favorite is a Shure V15vXMR. I have several head amps, so I could easily use the Yamaha.
Has anyone ever used this cart? Opinions? Where does this fall in the Yamaha cartridge line-up?
  #2
Old 03-11-2010, 01:47 PM
REDone REDone is offline
AK Member
Quite high I think, but check on the cartridge database on Vinyl Engine
No personal experience from me here (unfortunately)
  #3
Old 03-11-2010, 02:58 PM
junkaudio's Avatar
junkaudio junkaudio is offline
AK Member
i used mc 9 (about 100 $ in 1990 ) and mc 11 (70$ ) on a technics sl 1210 mkII with very good results
__________________
Don┤t you boys know any nice songs ?
  #4
Old 03-11-2010, 03:19 PM
theophile's Avatar
theophile theophile is offline
Pheasant Plucker.
Whilst I hope that you get an answer to your questions,I also hope that you will try using the cartridge.Please remember that some of the highest regarded cartridges in the world are made in Japan.The Yamaha will sound distinctly different to the Shure.
Have a listen to it,then get-back to us and tell us how the Shure and the Yamaha campare.
__________________
Turntable/Tonearm: Yamaha GT-2000/YSA-1
Cartridges: Stanton 980 HZS or Soundsmith 'The Voice'
Phono stage: Simaudio Moon LP 5.3
Line Stage: Hornshoppe 'The Truth'
Speakers: KRK Expose E8B Active Studio Monitors
  #5
Old 03-11-2010, 03:56 PM
lini's Avatar
lini lini is online now
just me...
PT: The MC-9 was the model above the base LOMC model MC-11. Yahama classified it as upper middle class model, which for my taste seemed pretty much spot-on. In fact it was very good for the price and measured pretty well, too. I never had one of these myself, though - but I had an MC-505, which was the successor of the MC-3 and MC-5 and sounded excellent to my ears. It's really a pity these thingies are hardly available anymore. If I knew a NOS source for these, I'd be happy...
Greetings from Munich!
Manfred / lini
Audiokarma
  #6
Old 03-11-2010, 07:06 PM
the-real-mandak's Avatar
the-real-mandak the-real-mandak is offline
AK Member
The MC-9 was the 5. out of 6 carts in the line up (they never did low-end carts), MC-1000, MC-3, MC-5, MC-7, MC-9 and MC-11 (the MC-21 is a high output version of the MC-11).
Yamaha did not manufactur the carts themself, this was done by Audio Technica and some of the Yamaha carts are relabled AT carts. So expect an open sound with a good amount of treble.
BTW. The cart can be quite old, the MC-9 was the longest running in the Yamaha lineup. It came with the 2. generation in 1981 and ran until the end of Yamaha carts in 1998.
__________________
Watson CD7501 :-)
Main: Yamaha PX-3; PF-1000; Thorens TD-166MKII; T-85; CDX-993; C-2x; M-85; TDL RTL3II
Computer: Yamaha; TX-900; CDX-870; CX-1000; A100; White Van Speakers and SoundBlaster Live
  #7
Old 03-11-2010, 07:45 PM
lini's Avatar
just me...
t-m-r: The 21 had a different enclosure and was a good bit lighter than the 11, though...
Manfred / lini
  #8
Old 03-11-2010, 09:07 PM
Nat's Avatar
Nat Nat is offline
AK Member
I went through two MC 7s with genuine appreciation -- tidy, neutral sound with good tracking. I suppose a bit more calling attention to itself might have made more of a vivid impression, but that's not what I wanted from it. On the other hand, the one MC 9 I picked up as NOS I never liked -- it just didn't track well, and when it distorted it was pretty noticeable. Now I suspect the damper was dried up, but a decade ago, I wasn't so aware of the effects of aging. But of course, age is an issue for all older cartridges, and so if it sounds good, then you've lucked out.
  #9
Old 03-12-2010, 03:52 AM
AK Member
Manfred / lini
Yes true, but try take a look at the specs. You will find the only difference is the body and output, the body was properly changed to eliminate problems due to the high output.
__________________
Watson CD7501 :-)
  #10
Old 03-12-2010, 05:08 PM
lini's Avatar
just me...
t-m-r: Well, I did look at the specs: Another difference is that the 21s use sendust coil cores like some of the more expensive LOMC models, whereas the 11s use permalloy cores. So, if you'd ask me, I'd rather say that all of the Yamaha MCs are technically related to some degree - whereas I don't see enough specific parallels to call the 21 the high output version of the 11...
Manfred / lini
Audiokarma
  #11
Old 03-12-2010, 08:16 PM
AK Member
Yes they have to make the high output somehow, but look at all the other data. The 2 carts are the only one's shareing all data execpte output and weight (I even think the price was the same) and then there is the funny thing with the 21 name, why that number and not another one?
But enough about this, the talk was about the MC-9; Phototone let us hear what you think about it.
__________________
Watson CD7501 :-)
  #12
Old 08-19-2015, 04:01 PM
audireofile audireofile is offline
AK Member
Yamaha MC9 cartridge
When I sent my Supex in or a stylus/exchange, I bought one of these MC9's new and still use it. It is quite good, but certainly not as good as the Supex 900, which I now save mostly for my Direct to Disc albums. These have been run through Audire POCO and Mark Levinson JC something or other head amps with no difference in sound (of the head amps) between them. The bass is a bit tighter on the Supex and the extreme high end is lacking on the "Smooth Sound" Yamaha, but it is quite listenable.
My Buddy has a Grace F-9 MM,which sounds as good, if not better than the Yamaha, even with my relatively cheap replacement stylus (eBay). I also like the Grace better than my Shure V-15.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
