I picked up a Marantz 4230 receiver recently that needed a bit of restoration work. Amongst other issues was that the word "volume" was worn off of the faceplate.
In consultation with thedelihaus (Paul) I found some "Color Laser Bake-On Water-Slide Decal Media". Essentially this is a material that you print on with a laser printer and results in a decal that you apply wet and then bake in an oven at 375 F for 15 minutes to give it permanence.
The next challenge was to find the elusive Marantz font. I found "Metropolis CT" at www.myfonts.com that is very close. The page allows you to type in text and chose the size to see a sample. After doing that I did a "print screen" and copied it into a graphics program and trimmed / resized to fit.
Once I printed it out, trimmed and applied wet it was ready for the oven. Before baking it is critical to remove all plastic trim from the faceplate which in this case was the bezel around the dial glass and the plastic grommets around the headphone jacks and the tape monitor buttons. If you skip this step you will have one ugly mess on your hands.
I think the result, while not 100% perfect looks quite good and I'm hoping will be durable. You can see part of the clear substrate around the lettering but it certainly passes the 2 foot / 2 beer test.
This technique can be used for most any light colored metal faceplate; new projects and restorations.
JimB
JimB
