Olson Clone III
Redboy
a few good watts
I just finished another one of these little amps a few nights ago. This one's exactly the same as the last one I built, which now belongs to member bsujeep. I realize it isn't very original to build a clone of a clone of a clone, but the little Olson amp that started my love affair with single ended tubes holds a special place in my audio heart... Cheesy, eh?
I had been thinking it would be nice to have one onhand to compare to other amps I have, and since I had the parts around, I started knocking holes in the chassis about a week ago.
In a bold moment, I just put it into the system and plugged it right in...
Music! :)
What's it look like under the hood? I'm trying to decide on a build for a small battery powered amp and I'm already playing around with a 6V6 and 807 SE and I should add a little EL84 to the list. Nice looking build, what did you use for a chassis?
Nate, that is one of the cleanest looking amps around.
Outstanding my friend.
How's she compare to the 2A3?
Scuzzer, I'll shoot some pictures when I pull it out a little later to put some holes in the bottom plate. I documented the whole build with the last amp in this thread. The chassis is a Hammond aluminum box and it's pretty tight - only 7" square.
I have yet to hear a bad-sounding EL84 amplifier, SE or PP; triode or pentode.
Just sayin'...
Yep. :yes:
Thanks Gary! This whole thing was made unnecessarily complex with the subplate assembly, but I wanted to eliminate as many fastener heads from the top as possible.
I can't fairly compare it to the 2A3 because my speakers at the moment are pretty limited, but the last one I built did a nice job of running with the big boys. I really like the sound a lot, but this one's still breaking in.
I was thinking of using the 7.4"x4.7"x2" Hammond for my build but I've got a steel sheet in the garage that's just begging to be turned into an amp chassis. I'm trying to make an ultra small battery powered integrated tube amp and I might be able to fit it all into a 5"x4"x3" enclosure.
Thanks for the link with the detailed pics.
It's Deja vu all over again ;)
I liked that amp (clone v.2.0) when I had it at the house for a spell :thmbsp:
RC
Yeah, bsujeep (Bill) has been enjoying that one for a while now. I know he's rolled a few different tubes through it to good effect, and might have some suggestions for what to try.
This one will make an appearance at a certain May shindig. :)
I'll be bending the copper into the same basic layout as the original but the sub-plate is a really nice idea. :yes: I don't have any extra so I would probably make it out of aluminum instead. I could get more but don't think it would be worth the extra cost.
Hey give me back my amp!! oh never mind it's still here phew almost had a heart attack!
I am sure it's little brother will sound sweet with a little break in time and roll some telefunken el84's, older bro LOVES them. I have rolled a few including a set of amperex bugle boy 7189's that I borrowed from sparksaflyin. Telefunken el84's and 12ax7's with a TVC pre into Khorns was just magic. It doesn't sound too bad through the ewaves either.
Bill
Proud owner of Dolly II:D
You know, I'm pretty sure I've got some Tele EL84s around here, too! I'll have to test them at some point since they came from a console pull, but with luck they'll still be fresh. 12AX7s I have many. Enough, anyway.
Bill, I know we talked about it but did you ever get around to putting ventilation holes in the bottom plate of your amp?
No I didn't put holes in it, instead I used small washers and lifted the bottom plate about 1/8" to allow air to come in and out the top. Didn't do any before after measurements, should have I guess, but it makes me feel better anyway.
I wondered if when you wired this one up if you changed the order of the heater chain so the 12ax7 was last?
Pictures
Okay, some inside pics. This was an excercise in short signal paths and soldering in tight spaces:
attachment.php
