grateful said:
If I remember correctly that method will give readings that are high. I think you have to convert the peak to peak voltage to rms by multiplying the ptp value by .707. then plug that value into the formula. Most meters read directly in rms volts.
The Vpeak squared divided by 8 x load resistance takes care of that. This is because power equals effective voltage squared divided by load resistance. Since effective voltage for a sine is peak divided by square root of two, and peak is peak-to-peak divided by 2, we get effective voltage = peak-to-peak divided by 2xsqrt(2). You square that and get peak-to-peak/8. Then divide by load resistance, and voila, you get exactly what was written two posts up.
Output power is measured at a set level of distortion, best observed with a distortion meter or spectral analyser, usually this is either the rated distortion, 1% or 10%. Usually, wideband measurements are made at 1% distortion, 1kHz either at 1% or rated distortion.
That being said, distortion increases very rapidly at the onset of clipping, so even just verifying the waveform visually on a scope is enough. No visible clipping on the scope will put you at about 1-2% distortion max - backing off just a little will drastically reduce distortion but only slightly (few %) reduce output power. Once you got to that point, measure the voltage.
Output voltage is best measured with a true RMS meter, or at least a wideband VTVM or regular voltmeter. Most RatShack digital meters are quite bad over some 300Hz unless you go for an upscale model, and most of those don't do too well over a few kHz, but even that is usually enough (see below). An aside: non-RMS voltmeters measure peak values but are internally calibrated to show 0.707 of it in AC volt mode, assuming you are measuring sinewaves and want to know the effective value. This assumption is fine for our application, but may be totally inapropriate for other applications.
Some words of warning:
1) Avoid measuring the full power bandwidth of an amp or indeed measuring power output at very high frequencies (say over 10kHz). If you do it, you need to do it very quickly. The reason for this is that the power at such frequencies in an audio signal tends to be very small even if the amp is driven to clip parts of an audio waveform. Assuming a non-inductive and powerful enough dummy load and a good power amp, the amp and load will have no problem with it, but the output amp compensation network (sometimes referred to as a Zobel network, the series cap and resitor in parallel with the output) will not take this for very long as it will be taking over the role of a load to a signifficant degree - and will eventually (sometimes this is measured on the order of 10-20 seconds) burn out the resistor. Full power bandwidth is best measured with the zobel taken off, and the dummy load connected via twisted pair directly to amp output on the board. All of this assumes the simple generator-amp-dummy load-scope+meter hookup. There are other much more complicated methods of measuring that do not require these precautions.
2) The maximum power dissipation of a class (A)B amp occurs at around 1/3 of the power output. Very few amps are designed to provide this power level on a continious basis. Some are not designed to provide the full power output on a continious basis. This is because the average power of an audio signal is only s small fraction od the peak power. Even so, an amp which cannot withstand these conditions for at least 10 minutes should be considered a bad design - or, put in a place that does not provide sufficient ventilation! In other words - keep the measuring short and/or ventilate the amp well. Keep in mind that testing for output power at low impedance loads stresses the amp considerably more than normally. Especially avoid asking for it by 'testing' the protection circuitry - it does not protect against stupid users! For low impedance loads, heat generated in the power supply and transformer may become an issue as well.
3) Keep your load well connected. Losing the load at full power can be disaster for some amps, even if they can be used without load assuming they were powered up without one. It is the removal of a load that can kill an amp because of inductive backlash - even connecting a load can cause this since it is near impossible to connect a load without contact bounce, hence a series of connects and disconnects. In other words: do not operate speaker switches at high power levels, keep cables sohort and braided for minimum inductance, and avoid inductive loads (blowing a fuse in an amp with a heavily inductive load can also lead to havoc). Also important to remember with bipolar amps: a hot amp will be considerably less resilient than a cold one.
