So I need what to bring my FISHER 400 down to a reasonable voltage from 124. a 120/10V 3-4amp transformer? Then take the one secondary(hot side) and wire it to the primary so the secondary is in series with the primary? and leave the Neutral to go thru straight? Kinda like a Dim Bulb Tester?
Ratshack should have something like that, right? The drawings I saw on 'net thru google intimated that but I'm not real comfortable just doing it.
This is how I understand it.
Say the transformer has 4 leads. 1 and 2 are primary. 3 and 4 are secondary.
Wire the Hot line from wall to 1. Tie 2 and 3 together, and 4 goes to hot side of line to unit. Neutral goes straight thru? Is this correct? But if I tie 2 and 4 together I raise the voltage. So i check voltage from trans 1st before hooking up receiver.
Use a bat if necessary to get it in to my thick skull, please.
Thanks
Larry
Thanks
Larry
