Patrice B
Hi,
I just bought the Eico today for a low price...
Ran the thing to test if it worked and (don't do it) put probably too much cleaner somewhere (maybe alcohol when cleaning the inside of the amp, or Deoxit in the pot!) and the power/treble switch is now obviously dead.
I jumpered the wires temporarily but is there a way to dismantle and repair the switch part (with pliers maybe...)?
I know I could rewire the switch on the obsolete tape speed slide switch instead but I wanna know if there's a fix before doing it.
Don't worry, I ordered the necessary caps for the rebuild...
Amazingly, no hum and clean sound even if some caps appeared to had bad time before.
BTW, it was full of Amperex Bugle Boy 12AX7's. However, all shields are missing and someone managed to drill holes in the cover to install two 1/4 inches jack for speaker outs (it was used by one of the precedent owner as a guitar amp... waste of hifi!!!)
**Treble is working in case you ask...
Thanks.
Patrice
Thanks.
Patrice
