Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 05-01-2010, 10:47 AM
BmWr75's Avatar
BmWr75 BmWr75 is offline
Not as old as I look
Quality problems with Russian 6P3-E power tubes
Posted this in another thread, but think a new one is merited.
I bought 8 of these Russian 6P3-Es tubes in recent months from eBay seller basa_79. Never installed them in an amp. Got a tube tester recently and tested all 8. Five were closely matched in GM. Three of them were bad......I could see the wire windings glowly very brightly on two of them and the meter went wild on my tester. One was just dead. I think all three of the bad ones came in the 2nd purchase and were in the original paper tubes. The first quad purchased had no paper tubes.
Buyer beware with this eBay seller. I've contacted him about the problem, will share the results.
__________________
About 1/2 of what you read on the internet is true......problem is knowing which 1/2!!
  #2
Old 05-01-2010, 12:15 PM
nerdorama's Avatar
nerdorama nerdorama is offline
AK member
This is the reason I bought from Jim McShane. I've heard a few stories like this. He takes the hit and culls that bad ones. His price isn't that much higher after shipping from Russia and they're guaranteed.
Please don't think I'm trying to rub it in. I almost bought from the auction until I heard some of these stories. If I wanted to buy a large quantity and cull them myself, then it may make sense to me. The Russian vendors from whom I've purchased items have all been very good, I just don't want to mess around with tubes that are a crap shoot in a small quantity.
I hope your seller will work it out with you.
Jim said in a post that some of his initially bad tubes worked ok after a number of hours of burn-in by just running the heaters to dissipate some internal gas problems. I think that was the story. It might be an answer to some of your bad tubes.
http://db.audioasylum.com/cgi/m.mpl?...hlight=6p3s&r=
Jim also suggests that possibly baking them in an oven would clear up some of the gas issues.
http://db.audioasylum.com/cgi/m.mpl?...highlight=6p3s
They sound very nice. I've heard them replacing both 5881's and EL34's.
Best,
John
__________________
De gustibus non est disputandum
VPI Scout, Denon DL-304,Wright WPA-200, DIY tube pre and amp, ADS 910, Lynn Olson ME2, Apogee Centaur Minor, Stax SR-X
  #3
Old 05-01-2010, 02:37 PM
BmWr75's Avatar
Two of the three bad tubes didn't have any silver flashing inside the top of the tube near the getters. Other than that they looked identical to the good tubes. What does the missing silver flashing mean?
I've bought from Jim McShane too, he's a good seller. I'll check out the 6CA7s he has.
__________________
  #4
Old 05-01-2010, 05:41 PM
Pio1980's Avatar
Pio1980 Pio1980 is offline
AK Member
"What does the missing silver flashing mean?"
Either they haven't been "gettered", or if a whitish powdery appearance very gassy or no vacuum due to air leak. All very bad and useless tubes.
__________________
"Different" is easy, "Better" not so much.
Goodness comes from getting the basics right, glory is to be found in tending to the details.
  #5
Old 05-01-2010, 08:10 PM
BmWr75's Avatar
Here's a picture that shows a tube with the missing silver flashing.
__________________
Audiokarma
  #6
Old 05-01-2010, 08:20 PM
Ty_Bower Ty_Bower is offline
AK Member
The flashing is still there, it has simply turned white from exposure to air. That tube has lost its vacuum and is no longer good. Nothing can be done for it.
__________________
Surface morphology is not a contributing factor other than the specularity of the finish.
  #7
Old 05-01-2010, 08:57 PM
Bluelobster's Avatar
Bluelobster Bluelobster is offline
AK Member
These Russian tubes are really good once you get a quad that works and is suitably matched. Don't give up on them I think you will like them, certainly better than any 6ca7 out these days. Set them up so that they are about 23 watts output per pair, that seems to be their sweet spot.
A fellow over at the Asylum, goes by "Twystd" turned me on to them over a year ago. I first put them in an ST70, then Dynaco MKIV and was really impressed and happy.
BTW the tube with the clear top lost it's vacuum, hence no getter. These tubes have been around unused for years so it may not be the sellers fault unless he said they were checked and tested.
  #8
Old 05-01-2010, 09:05 PM
BmWr75's Avatar
The two tubes that have clear tops had not been tested. They were still sealed in the original paper boxes, rusty staples and all. The other bad one was probably also untested.
The 5 good ones are pretty well matched. Will give them a go in my ST70.
__________________
  #9
Old 05-02-2010, 10:17 AM
neon the cat neon the cat is offline
AK Member
6p3e
I like this tube, and was turned on to them by Ty Bower (thanks, Ty!).
A quad I ordered from ebay seller, nixiestore, had one tube DOA (filament).
Jacob sent a new tube immediately from his Russian warehouse. Trustworthy guy, I will buy all my Russian tubes from him in future.
Since then, the tubes have been working and sounding very good.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Analog Engineering Associates
Okki Nokki
Hudson Valley Hi Fi
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
