#1
6BM8 Volatge regulator
Anyone ever use the 6BM8 as a voltage regulator?
__________________
Encumbered by idjuts, we pressed on. |
#2
I've seen it used in some PS arrangements, but I can not recall which ones, and how/what they actually regulated. Neat concepts, but nothing I've built/played with (yet).
My only problem with using 6BM8 in a PS is that I don't have many of them, and I can't find them cheap ever as they're a semi-popular output tube. Would be nice to find some PS schematic with more obscure tubes. What'cha building? This for the preamp? |
#3
Yep, the preamp PS. I saw a design somewhere that used feedback to the triode grid to regulate. I thought it would be neat to do a different type of tube regualtion, and I think I will only need two.
__________________
#4
Quote:
__________________
Channel your inner hillbillly. |
#5
That's it I think! What is the heater bias terminal all about??
__________________
| Audiokarma |
#6
That is a question for Eric Barbour as I sure as hell don't know.
__________________
#7
Whatwould the second valve be?
Oh, never mind. I see iot's the 2nd half. Looks interresting! |
#8
I had an answer but wasn't sure it was right so I deleted it.
#9
The heater bias allows you to keep the heater-cathode voltage within ratings.
Where can one buy some of these tubes without paying top dollar? |
#10
A pass-tube! Looks like a pass transistor in a solid-state regulator...
| Audiokarma |
#11
Russian 6F3P. About $4 or so each.
#12
Quote:
http://www.the-planet.org/6GV8.html Jeff |
#13
Well you can buy those tubes at about $4.50 but shipping cost puts it out of the running.
Those regulator circuits have a major flaw. The zener diode is a high voltage unit and its temperature coefficient of voltage is high. So the output voltage will climb considerably as it warms up. If I remember correctly, the coefficient runs around .12% per degree C so if there is a 40 degree rise the voltage will climb about 5%. For 250 Volts that will be 12 or 13 Volts drift. A more stable solution would be to use a VR tube. Their coefficient is very small and they are available in several voltages from 75 to 150 Volts. Last edited by Bob91343; 05-31-2010 at 12:43 AM. |
#14
Quote:
Quote:
__________________
#15
Quote:
__________________
| Audiokarma |
| Thread Tools | |
| Display Modes | |
