schufflerbot - can you post pictures of what fell out of the tonearm base?
FYI - the stock wire in the arm is not Cardas. "Cardas" is a manufacturer of high end audio accesories and components. Their tonearm wire is widely regarded as being one of the best upgrades you can perform on arms with the stock wire intact.
KAB uses Cardas wire in their upgrade - they replace from the bayonet where the headshell screws in to either a Cardas DIN plate at the bottom of the arm or a plate that mounts on the back of the table with female RCA's. I believe KAB keeps the PCB board at the base of the arm in place when doing the external RCA plate to act as strain relief when mounting it. I'm not sure about that, I've only had tables from them with the Cardas DIN plates - the PCB is removed when using the DIN plate. They charge about $170 for the service.
Applied Fidelity uses Cardas wire in a continuous run from the bayonet to to a set of male Vampire Wire RCA's. I've got a table that was done by them as well and prefer their method. The external wire is nicely shielded and dressed and, to my ears, it's the best sounding of all the SL-1200 wire mods. It's considerably more expensive at $295, but worth it in my opinion.
Cardas Wire
Applied Fidelity
