chicks
Lunatic Member
Picked up this A-80 @ the GW a couple of days ago. I like the nice clean look of its face. Internally, it's a rat's nest, however. Build quality definitely not the same as the '70's Pioneer gear. I think this one was built from '82-'84 or so. Has a similar look to my Rat Shack STA-2270 receiver. I like the built-in MC transformer, and switchable MC impedance matching (will need to get a MC cart one of these days). 150Wpc, very low distortion, "Dynamic Power Non Switching", whatever that means. Two power supply voltages, one for normal listening, a higher one for the peaks.
Seems to be a very rare bird in the US, not much info out there. This one has multiple input voltages, probably the US Military version. It was set at 110V when I got it, possibly causing some stress on the internals.
Protect relay wasn't clicking, and the power light is burned out (why did they use incandescent bulbs for the power/protect lights, and LED's everywhere else? :screwy: ) Troubleshooting revealed that R42 & R43, a pair of 10 ohm 1/4W dropping resistors on the driver boards, were wide open. No sign of heat distress on either one, they simply failed - probably poorly made.
Replaced both (a major job, as the driver boards are vertically mounted and a PITA to access and remove), powered up, and heard the protect relay click!
Offset measured ~3mv on each side, good to go.
Well, almost - left channel now works fine, right is still dead. More troubleshooting to come...
Offset measured ~3mv on each side, good to go.Well, almost - left channel now works fine, right is still dead. More troubleshooting to come...
