boreas
"If it sounds good, it IS good." E.K.E.
I recently picked up a pretty rough* Sansui SR-1050E. I've so far determined that it works but it needs a fair amount of TLC right down to either major plinth repair or perhaps a new plinth (which would be a fun project).
Anyway, my specific question: the belt that came with it was either the wrong one from the get-go or horribly stretched so of no use. The online sources that list a belt for this table specify conflicting belts. All say that a 25" belt is correct and, while several sources list a wide belt, one source specifies a medium.
I have a 25" medium on another turntable so I gave that a try. The table runs fast.
Does anyone know firsthand what the correct belt for this table is? I read a comment in an old thread that Sansuis use wider than normal belts but the comment also said that a normal width (medium?) makes the deck run slow. I'm confused.
Thanks,
John
*The attached photos are after considerable work to the deck, platter, dustcover and internals. The plinth is the only area still needing attention.
Thanks,
John
