Did Sylvania make all the 12AX7A and 12AU7A Baldwin organ branded tubes? Found only one link on a Google search that suggested this was the case.
Just looked at my red label tube, and it says Made In Japan, and it has 2H on it. Not sure if the code is missing or just worn off, but I'd guess its probably a Matsushita or Hitachi?
. . . Tube on the left is a Baldwin 12AX7A (most likely Raytheon produced), yellow label, black plate, halo getter, date code = P28061-250
Tube on the right is a Baldwin 12AU7A (most likely Sylvania produced), green label, grey plate, halo getter, date code = 31 12 26
Anyone have any experience with how these might compare sound-wise to the more famous European produced tubes (Amperex, Mullard, Telefunken, etc.)?
If it's a Matsushita, it's still a very good tube to have.
Wasn't that factory tooled by Mullard?
Philips set up the Matsushita plant, and brought in tooling from both Mullard and Amperex facilities. And the Japanese ran it with their typical obsessive attention to detail, so the tubes are very well made.
