Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Off Topic Forums
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 09-12-2010, 08:05 PM
kotofei's Avatar
kotofei kotofei is offline
permanent gear evolution
Broken microwave: bad magnetron?
Greetings everyone,
I post here since AK has many people familiar with principles of microwave emission.
My belowed home microwave oven, Samsung mt1066sb, broke today after 7 years of service. It doesn’t heat anything in the microwave mode, just make a strong buzzing sound which hasn’t been there before. All display functions work and the turntable rotates. The Samsung has built-in grills, they continue to heat and are controlled by timer as before; importantly, no buzzing sound is heard in the grill mode.
I opened the oven and didn’t see any gross damages, blackened parts or bad connections.
Since this oven works as a conventional grill (i.e. bake, broil etc) and only microwave “part’ is broken, I would like to fix it (especially if one takes into account that replacement is around $250 and is available only online).
Internet searches points at a faulty magnetron as the most likely source of this problem. Samsung magnetrons are available at epay (new) for around $50 and replacement looks pretty straightforward.
However, I don’t know what might be a reason for a magnetron going bad and how one can test magnetrons. Could it be that some component connected to the magnetron went bad and this cause the oven malfunction or killed the magnetron? I noticed a HUGE transformer inside the microwave oven which probably powers the magnetron; could it be shorted?
Any advices of those who changed magnetrons, diagnosed or fixed microwave ovens or just opinion on this subject is greatly appreciated.
__________________
Mitsubishi LT-30 w/ Dynavector Karat 17D3
Nakamichi CDP-2A
Nakamichi Dragon
Nakamichi ST-7
Nakamichi CA-7A
Bogen AP-200 tube integrated
Vandersteen 2CE Signature
and rehab for other orphaned and injured gear
  #2
Old 09-12-2010, 09:08 PM
chillwolf's Avatar
chillwolf chillwolf is offline
"Play 'em off!"
If the the magnetron goes it usually doesn't make any noise when operating. Sounds more like the hi voltage transformer to me. To check the transformer for continuity you will need an electrical schematic of the system to see see what the values are supposed to be. Replacing a transformer is a fairly straight forward job in most microwave ovens, except for some of the over the range models. Just make sure to discharge the hi voltage capacitor before attempting any repairs! And make sure that you get your wires on the correct terminals on the transformer if you replace it. A lot of times the replacement transformer will not have it's terminals in the same exact location as the original one.
Most every failed magnetron that I checked as an appliance tech, usually had a hairline crack in one of the big magnets.
The loud buzzing sound is usually an indication of a failed hi voltage transformer.
__________________
"The worst thing about getting old, is remembering when you were young."
  #3
Old 09-12-2010, 10:10 PM
kcollins4's Avatar
kcollins4 kcollins4 is offline
Rocking somewhere
You mentioned info from the internet pointing you in this direction. Don;t know if you've looked, but Samsung might have troubleshooting charts for your MW. Many MW's have the service pack inside the unit, under a cover.
__________________
Kevin
  #4
Old 09-12-2010, 11:31 PM
RickB's Avatar
RickB RickB is offline
On the Road to Find Out
Might be the high voltage rectifier diode...I saw ten times as many diodes blow as I did Magnetrons, I started working on appliances back in the early '60's as my family has owned a major home appliance service agency since 1952....still own it, but business isn't what it used to be...
The strong buzzing sound is what is usually a tip off to me...
The diodes are fairly inexpensive, I'd take a multimeter to the one that's in your machine and see if that's it...it will conduct one way but not another...that is, if it's good...a bad one usually blows and shows infinite resistance....
good luck
__________________
[SIGPIC][/SIGPIC]
Linn LP-12/Ittok LVII/Benz Ruby
Lenovo H530S, Micromega MyDAC, Squeezebox Touch
AI Modulus 3A, Sound Valves VTA-70i,
Triangle Plaisir Kumas
  #5
Old 09-13-2010, 11:01 AM
Brian's Avatar
Brian Brian is offline
An Old Geezer
I have a similar much beloved old microwave/convection oven and it has gone down 2-3 times since puchased in 1985. Each time the convection oven would work and the microwave would not. Surprisingly, each repair was cheap at the shop and simple. Bad interlock switch and wiring, safety switch alignment and electronic circuit board repalcement. The latter I thought would finish the unit off as so few were made. The tech located one and the cost was only $50 installed.
__________________
Sherwood S9500c amp & S3300 tuner, Koss ESP9, Thorens TD160, ADC XLM III Super, Philips CD150, Wharfedale W70, Tandberg TDC310 Cassette
Audiokarma
  #6
Old 09-13-2010, 01:37 PM
markdi markdi is offline
markdi
sounds like a bad diode to me
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
