From working on my 1000A, a few observations.
Leads on components are much thinner than USA made parts. So, they may break if too much wiggling etc. is done. The terminal strips are "J" shaped a lot of the time instead of just being a lug with a hole in the middle. You can often carefully unwrap the old component (read: NASTY gray capacitor
) if you try. I used a solder sucker first to remove almost all of the solder. Tube sockets are much like USA manufacture so no big difference.
Resistors are fragile and the ends come off easily. But there are usually no unusual values. The auction site has resistors by the kit, with most values and in 1% from vendors in the Far East. I have found them to be reliable and usually spot on value. So if you damage one, just sit back, take a swig of your favorit adult beverage and call it a night. Tomorrow is another day as the song goes.
Electrolytic capacitors most likely should be replaced. If they get warm, they MUST be replaced. Keep in mind that often a warm electrolytic cap may be getting heated by tubes very near by. I don't know about the 500A, but the electrolytic filters are usually 500 WVDC. So, the usual 450 WVDC that are plentiful are not good enough.
Tubes will most likely be OK. They are usually the last to go. The only exception may be the outputs. But don't throw them away. And whatever tube is in front of the outputs, 6AN8, 12AX7, whatever, even if it measures way low, it will still work just fine. Japanese tubes are not junk. They are very good, usually made by Toshiba, Matsushita etc.
Take your time, don't rush it. You have a museum piece in your hands. When done properly, you will be rewarded with hundreds of hours (yes hundreds) of trouble free use. BTW, a fan may help. these guys get very hot and heat is an enemy.
Another whole thread can go on about lowering the input voltage if yours is high.
Enjoy, keep us posted, and pictures would be nice. Also, I am sure that the Sansui database would really benefit from a scan of the manual. Even though I don't have a 500A, I may some day. I do have also a 1000 (in addition to the 1000A). That is a strange bird. Still in queue for restoration. Only a few caps replaced so far. Check them out and look at the output tubes. They are European TV Horizontal Output Tubes...
