Live_Wire
Realistic Ak'er
I found one of these on the bay and decided to throw a bid up on it ($5) so I figured why not, turns out I was the only bidder so I got it.
I didn't expect much, ad said it wasn't working and in the picture it was missing the record level knob and it looked quite bad (the top look as though it was pulling away from the unit). It arrived today, for the most part together. The top was off and the knob and a few screws were in a pill bottle (quite surprised, I didn't expect to get it ).
I already had a good idea as to what was wrong with it, and I confirmed it as soon as I plugged it in. The belts are worn out. The heads get stuck in a half way up position and the solenoid will just click twice and it won't do anything. So, I helped it along by moving the flywheel on the back of a capstan and it clicked to life. The heads popped up and starting playing.
I changed out the belts and gave the heads a really good cleaning while I had the mechanism out then put it all back together. After I had it operating on the bench, I looked at the lid again, it looked really shiny but yellow and scratched. I realized it still had the protective plastic on it! Underneath, the metal is mint! :thmbsp:
I have it on my bench playing dredg and I cannot believe the sound. It's still a little slow because of the tension on the belt (they stretch out a little bit and go back to normal speed within 2 hours).
The quick reverse feature is working perfectly too.
This cassette deck is identical to the Realistic/Optimus SCT-88. Here are some pictures of it on my bench.
