mattsd
Hey everyone!
I have a new problem receiver, this time all the outputs are intact. But it would appear that either the drivers or something else is messed up on the left channel. There is a varying DC voltage at the left speaker terminals between 1.72 and 1.96v. Here are the voltages for the transistors:
Q1 Base: 55mv
Collector: 36.20v
Emitter: .617v
Q3 Base: 63mv
Collector: 37.26v
Emitter: .617
Q5 Base: 36.4v
Collector: Varying between .914 and 1.3v
Emitter: 37.1v
Q7 Base: Varying between 3.08 and 3.26v
Collector: 28.70v
Emitter: Varying between 2.48 and 2.80v
Q9 Base: Varying between .711 and 1.05v
Collector: 28.70:
Emitter: Varying between 1.21 and 1.42v
In contrast, here are the right channel voltages:
Q2 Base: 12.5mv
Collector: 36.20v
Emitter: .562v
Q4 Base: 19.3mv
Collector: 37.26v
Emitter: .562
Q6 Base: 36.4v
Collector: 1.24v
Emitter: 37.1v
Q8 Base: 1.16v
Collector: 28.70v
Emitter: .564v
Q10 Base: 1.24v
Collector: 28.70v:
Emitter: .641v
The question is which component is failing. I've diode checked all the left channel transistors and they checked just fine. Q1 and 3 are 2sa726's, which I know have bad reputation on here for failing or becoming noisy. Q2 and 4 have been replaced with Motorola 2n4126 transistors, but not by me. I have not connected any speakers to it yet.
Update: Since the right channel seems to be working properly I connected a speaker to it and gave it a listen with a CD player through the AUX input, and another problem has presented itself. It's like listening to a FM station with a lot of static. I have cleaned the volume control and I varied it while listening to see if the static changed or went away and it stayed the same, no matter where the volume control was. I also did a little more reading and the 2sc1451 has a bad rep as well. Could this be why it sounds the way it does?
Q1 Base: 55mv
Collector: 36.20v
Emitter: .617v
Q3 Base: 63mv
Collector: 37.26v
Emitter: .617
Q5 Base: 36.4v
Emitter: 37.1v
Collector: 28.70v
Collector: 28.70:
Q2 Base: 12.5mv
Collector: 36.20v
Emitter: .562v
Q4 Base: 19.3mv
Collector: 37.26v
Emitter: .562
Q6 Base: 36.4v
Collector: 1.24v
Emitter: 37.1v
Q8 Base: 1.16v
Collector: 28.70v
Emitter: .564v
Q10 Base: 1.24v
Collector: 28.70v:
Emitter: .641v
