Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-05-2010, 10:26 PM
gadget73's Avatar
gadget73 gadget73 is offline
AK Member
807 vs 6L6 as an output tube
Does anyone have input on the sound of an 807 vs the 6L6GC ? I'm possibly looking at buying a mate to my Stancor Williamson amp, and its been modded to take a 6L6. I have one thats still fitted with the original 807 tubes. If I did get this, I'd probably be buying 4 tubes of either type but I'm looking for thoughts on which type to buy. I'm sort of leaning towards the 807 for price and the fact it has that cool plate cap, but should I really consider a 6L6GC or a KT66 or something ?
http://www.pmillett.com/file_downloa...schematics.pdf
the second set of schematics for the amp in ultralinear mode is what I'm working with.
__________________
solid stuff, tube stuff, its all good stuff
  #2
Old 11-05-2010, 10:34 PM
jaymanaa's Avatar
jaymanaa jaymanaa is offline
More Wag Less Bark
Just my ears but I'll take a 6L6 over an 807 / 1625 every time. They sound better to me, and seem to be much more durable.
__________________
Hopeless victim of Fletcher Munson Effect.
  #3
Old 11-05-2010, 10:41 PM
battradio's Avatar
battradio battradio is offline
AK Member
Hi ,
I would consider the 6BG6 , wire both chassis for these they are reasonabled .
http://www.vacuumtubes.com/6BG6.html .
Your would have the advanages of the 6L6GC with the price of the 807 .
__________________
I just hate that when you wake up and find out you are Conti the brain damaged robot and even worse than that the perfect audio system you had is gone !
Mark
  #4
Old 11-05-2010, 10:44 PM
gadget73's Avatar
AK Member
moot point, had a login issue and ended up missing out on it. There are days where I truly despise technology. Stupid login timeouts.
__________________
  #5
Old 11-06-2010, 03:22 AM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
Last of the Time Lords
Quote:
I wonder how, since the 807/1625 is just a higher-voltage 6L6.
__________________
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Burn the land and boil the sea...you can't take the sky from me.
-Joss Whedon
Audiokarma
  #6
Old 11-06-2010, 06:52 AM
seta1 seta1 is offline
AK Member
[QUOTE=gadget73;4120030]Does anyone have input on the sound of an 807 vs the 6L6GC ? I'm possibly looking at buying a mate to my Stancor Williamson amp, and its been modded to take a 6L6. I have one thats still fitted with the original 807 tubes. If I did get this, I'd probably be buying 4 tubes of either type but I'm looking for thoughts on which type to buy. I'm sort of leaning towards the 807 for price and the fact it has that cool plate cap, but should I really consider a 6L6GC or a KT66 or something ?
/QUOTE]
The problem with the 807 is that it is no longer made while the 6L6 is still in production. Although vintage 807's are not priced in the stratosphere yet, it will only be a matter of time before their prices go crazy. The 6L6 sounds great and is as good or better sounding then the 807. The 807, though, looks cooler.
As for the KT66, it is NOT a drop in replacement. It's filament current is half again the filament current of a 6L6. This can be fatal to certain amplifier's power transformers. This is especially true with vintage amps which normally have power transformers that are just adequate with no reserve capacity. Can't tell you how many Fender guitar amps I have had to replace power transformers in because someone decided to cram a set of KT66's in place of the correct 6L6GC's. Also, the 6L6GC is a 30 watt plate dissipation tube while the KT66 is rated at 25 watts. The KT66 is what is called a "Kinkless Tetrode" while the 6L6 is a beam pentode. Just remember that for every pair of KT66's used in an amp, you need 1 amp more filament current then what you would for a pair of 6L6's.
__________________
Scott 340, Dynaco PAS2, ST70, FM1, Scott LC21, Scott 299C. Scott 210F, Scott 399, Marantz 2270, Marantz AV500, Acurus A250, Nikko Beta 20, Nikko Alpha 220, JBL 4411,
  #7
Old 11-06-2010, 08:20 AM
sebrof's Avatar
sebrof sebrof is offline
AK Member
I have an amp that was designed for the 6L6, and I got adapters so I can drop in 807s. RCA NOS 807s are dirt cheap and to me sound much better than the new production EH 6L6s that came with the amp. Also better than an old pair of 6L6s (Sylvaina??), but I'm not sure of the history of that pair, they may be spent.
As far as durability - My understanding is that the 807 is one of the most durable tubes on the planet (as far as audio output applications), having been designed as an RF transmitter tube and made mostly for the military. I've read stories of people in the Ham Radio world pushing them way way beyond their rating and running them that way for years.
I believe that any amp that takes 6L6s will take the 807 with the adapters. $50 for the adapters, and NOS in the box 807s will run you about what a pair of new production EH 6L6s will.
  #8
Old 11-06-2010, 08:31 AM
jon_s's Avatar
jon_s jon_s is offline
AK Member
Quote:
Fortunately they both mean the same thing, just different marketing
  #9
Old 11-06-2010, 08:42 AM
ducati_EL34's Avatar
ducati_EL34 ducati_EL34 is online now
AK Member
Quote:
Well Amateur radio operators are not worried about high fidelity, just a clean 800Hz CW tone...
Along those lines, there is a guy who builds old CW transmitters, 1929 vintage, and use 45 tubes for the finals. He says he buys "weak" ones from the hi-fi guys, who no longer find them fit for hi-fi grade audio...
__________________
“I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.” -- Frank Sinatra
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Okki Nokki
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
©Copyright 2002-2014 AudioKarma.org, All rights reserved.
