The top is aluminium, the base is plastic, right?
John I used Rustoleum on my one 1800MKII and on my 1700MKII. The best finish I got was using the Rustoleum and a clear Lacquer vs just the Rustoleum finish. The Lacquer finish after several coats took on that deep high gloss finish where as the non one had more of a semi or light gloss to it......... but I'd say if you haven't purchased the paint yet to forget the rustoleum and pick up some duplicolor paint as it will give you a much better finish.......... with a lot less work.........
Thank You for that info. I bought the Rustoleum but, I can return it for the proper paint.
Thanks,
John.![]()
Here we go - straight from the manufacturer's advertising brochure, "The outer base is made from diecast aluminium.....The inner base, which supports the all-important platter, motor and tonearm base, is made from our heavy, anti-resonant "TNRC" material (Technics Non-Resonant Compound)."![]()
:scratch2:It may be the Mark I SL-1700 used a different material - the brochure I had was for the Mark II version, and they may have decided TNRC was a better material than aluminium for the inner base, and changed it.
Here is something I just noticed and wondered about. The arm base is painted the same color as the plinth on these NON MKII tables/ Are you going to leave it the stock color or paint that as well?
Very nice work you are doing there, John. Can't wait to see how she finally turns out.
